September 9, 20223 yr Hi all, Can I have some recommendations for cable thickness between DB and inverter for both a 5.5 and 8 kw inverter? Inverter is about 10 meter max from the DB. Possibly 4mm2 surfix for 5,5kw and 6mm2 for 8kw.......... Thanks
September 9, 20223 yr 2 minutes ago, Namreh said: Possibly 4mm2 surfix for 5,5kw and 6mm2 for 8kw That should be perfectđ
September 9, 20223 yr 43 minutes ago, Namreh said: Hi all, Can I have some recommendations for cable thickness between DB and inverter for both a 5.5 and 8 kw inverter? Inverter is about 10 meter max from the DB. Possibly 4mm2 surfix for 5,5kw and 6mm2 for 8kw.......... Thanks I will for sure not run the 8kW with a pass through current of 50A on a 6 sq mm cable.
September 9, 20223 yr 49 minutes ago, Namreh said: Hi all, Can I have some recommendations for cable thickness between DB and inverter for both a 5.5 and 8 kw inverter? Inverter is about 10 meter max from the DB. Possibly 4mm2 surfix for 5,5kw and 6mm2 for 8kw.......... Thanks I would do 6mm2 on a 5kw and 10mm2 on an 8kwÂ
September 9, 20223 yr Author 4 minutes ago, Scorp007 said: I will for sure not run the 8kW with a pass through current of 50A on a 6 sq mm cable. Thanks, So 6mm2 should be fine for 5.5kw and 10mm2 for the 8kw
September 9, 20223 yr  But bigger is better Best guideđ  Edited September 9, 20223 yr by Quwatush Shams (Suly)
September 25, 20223 yr On 2022/09/09 at 5:26 PM, Leshen said: I would do 6mm2 on a 5kw and 10mm2 on an 8kw ^^^This. The extra cost is largely negligible.
