October 28, 20223 yr I saw this setting on the Sunsynk.net platform settings under Battery settings? Can anyone explain these settings. The only thing I found is "Grid Signal: Indicates when the grid should no longer charge the battery. " Thank you. Edited October 28, 20223 yr by Milan188
March 10, 20233 yr Reviving this topic. I'm assuming the Timer options override this setting... Any thoughts? Anyone?
March 10, 20233 yr That grid signal is confusing as well Its to signal a relay. Probably to switch the grid back off Edited March 10, 20233 yr by Chris_S
