October 31, 20223 yr Hi the client imported the above.Maual of battery not stating what dip switch settings should be etc.Basically nothing. Any help wil be appreciated. Growatt spf 10000 T DVM. What cables for canbuss etc
October 31, 20223 yr Is there no Specification/Data sticker somewhere on that battery that provides some clues about the origin/manufacturer? Edited October 31, 20223 yr by zsde
November 1, 20223 yr ...and perhaps a pic of the BMS ports and dip switches, it might be possible to tell what BMS it uses. On a lot of batteries the dip switches are all down if there is only 1 battery, but on some they need the first dip switch up to set the baud rate.
November 1, 20223 yr Author Hi guys thanks for response.On the battery no placard.Its quite odd.it has the Bms input and R485 and i think give dip switches.Ill take a pic and upload
November 4, 20223 yr Unfortunately I don't recognise that BMS, hopefully someone else might. That is certainly a large choice of comm ports, which is good and they have at least clearly marked the pin counts.
November 4, 20223 yr Looks like the same one that comes in the Hubble, BSL, FreedomWon eTower and others. The dipswitches aren't the same for all those, as the firmware is different, but start by reading the manuals for those.
November 4, 20223 yr 11 hours ago, Roadrunner said: That style looks very similar to the greenrich batteries, same cheapish looking looking switch, and the bms layout of the ports looks almost identical. Edited November 4, 20223 yr by WannabeSolarSparky
November 6, 20223 yr Author What i find confusing is that there is no placards on the battery.There is no manual for batteries .He only sent me an ekectronic one which basically tells you nothing.
January 7, 20233 yr The BMS looks like a PACE one ( like whats in hubble AM2, and CurrentConnected SOK and Jakiper ), you shuold be able to use PBMSTools to speak with it and change some protocols https://www.currentconnected.com/product/sk48v100/
