Sonoff Loadshedder Lucky Draw Bundle
4 hours ago, Boreddesigns said:
Thanks, I'll have a look into that. So the two smart switches would be linked to the relay using the ewelink app?
The concept of a scene means you group a number of timers together so you perform 1 switch action and all of them change state.
That is what Peter meant with a scene.
  • Replies 58
  • Views 13.6k
On 2023/03/12 at 10:33 AM, jezzad said:
Purchased a SONOFF Load Shedding Detector Kit from GeeWiz - https://www.geewiz.co.za/sonoff-pro...-shedding-detector-kit-with-instructions.html
Image and instructions for install are for a Sonoff Mini R2 with S1 and S2 connections.
Actual product that was delivered had a Sonoff Mini R3 in the box with two L and two N connections. No actual switch connections.
Electrician is here trying to install it and is a little concerned that they are not the same devices and are missing contacts.
Anyone install one and run into similar issues?
Update on this, GeeWiz sent me a replacement Sonoff Mini R2 as a replacement, must have been a packaging mistake.
On 2022/11/24 at 10:43 AM, Sonoff Africa said:
Hi, Sorry guys it been silly crazy trying to find a minute to answer as often as I can.
The Load Shedder is a smart power detector that turns off appliances such as pool pumps, Geysers, and anything else you would like to switch off when load shedding starts.
It also recover's the load when eskom power is back with delays.
No additional re-wiring of DB board is required. All appliances that need to be controlled require smart devices like Sonoff Basic or any other Sonoff products.
Aleks
Aleks,
Will the device override a schedule created in the eWeLink App? I have a Redpole Switch connected to my Geyser and defined the following:
On: 05h00
Off: 07h00
On: 11h00
Off: 14h00
On: 18h00
Off: 21h00
If LS kicks in at 10h00, will it override the scheduler when it tries to switch the Geyser on at 11h00?
The Sonoff Africa Loadshedder team has found a very simple way to sort that out as the last command is always true with Sonoff. It really took us a year to test all the possible combinations.
Sorry, my phone died as I was typing the response and have just run out of time.
If you did not get the links with our product just give me a shout and I will send them to you.
Aleks
I would like to express my sincere apologies for the unpleasant experience you had with their product. It was never our intention to have the brand tarnished by the actions of other companies in the smart home market.
As the original designers of the product, we did not anticipate that it would be misused or misrepresented by our competitors. We have requested that they remove the product from the market, or at the very least, provide a product that is of comparable quality and support.
Moreover, we have made our product available to them at a wholesale price. Our aim is to ensure that all customers, even those of our competitors, receive a high-quality product and excellent support.
If you require any assistance with the configuration of their product, please do not hesitate to contact me at 0823793860. It is our sincere hope that no customer, including our competitors' customers, will have to undergo a frustrating experience.image.thumb.png.b4083bed32516b1d077545b8f7c989ea.png
Edited by Sonoff Africa
No need to apologise, somethings are out of your control. I have setup the load shedding switch.
Apologies if asking something obvious, new to this all.
- Does the loadshedder fit into a BD or does it need to be mounted outside of it?
- I recall reading it works with Tuya. So if it connects to Tuya, I can use Tuya to create a scene triggered by the loadshedder, which would turn off a bunch of smart switches (like CBI astute)? Or does this only work if the smart switches are Sonoff smart switches?
- what high amp sonoff smart switch could I use to turn off a geyser, and a stove/oven?
The Sonoff LoadShedder fits in the DB Box
Sonoff MiniR3 Pool (Smart Timer)
Sonoff POWR320D Geyser (Smart Timer)
https://www.sonoffafrica.co.za/product/sonoff-loadshedder-bundle/
You can use the coupon code "PowerForum"
Will give you an additional discount.
Bundle Pack is more cost effective.
Aleks
