Hubble vs shoto
Afternoon Guys.
busy with purchasing my hybrid system.
have a 8kw sunsynk and 5kw of panels.
i either want to purchase 2 x hubble am-2 or 2 x shoto 5kw to start off with. Both are similary priced as i have contacts for both.
which is the better battery? I have read up on problems on both.
my installer recommends shoto as that is what he normally uses.
thanks
I would go with sunsynk as i think the warranty might be better if you have a sunsynk inverter.Dont get hubble.Lots of us have had tons of issues with the am2.
I have an 8kw sunsynk and would dump my 2 x am2 for sunsynk batteries or another brand.
13 hours ago, zsde said:
especially when paired with Sunsynk. Other Inverters too but most troubles were that combo.
Well I think that's probably the most common combination. Indeed I wonder if the most popular combionation in SA right now is Sunsynk and [fill in battery name].
I always think that inverter and battery should be considered as a combination. They need to get on nicely with each other.
Coming back to the original question, I think there is value in going with what your installer regularly uses. You can expect that he has a good relationship with that company, can access various support functions more easily than you can, and that he has familarity with those products. Sure, he's getting a cut of the action, but his relationships and knowledge should (if he's not a fly by night) add value and make the process smoother if you don't have the technical skills to do it yourself.
  • 3 months later...
HI there has anyone heard anything about the Dyness batteries as i want to install a 8 KWH Deye inverter with 2x 5KWEH batteries .
Please also advise on whom is the best priced and where to get these  .
Dyness is decent, similar to Pylontech. Just noting that both are 0.5C discharge so if you only have battery then you are limited to a max discharge power of 50% total capacity (2.5kw on a 5kw battery) - you can still go through the whole 5kwh of battery storage
I have 3 of the A48100 model and haven't had an issue in the 18months we've had the system
Edited by mzezman
clarified the 0.5C
