February 17, 20233 yr Good day I want to buy a 8.8kw Sunsynk inverter but I need to know what is the difference between the normal Hybrid and the ECCO Hybrid
February 17, 20233 yr Never heard of an ECCO Hybrid, except in in the model designation of a certain Luxpower range. Where did you hear about it? Examples?
February 17, 20233 yr Author https://www.sunsynk.org/8kw-hybrid-inverter pse see this Sunsynk link above - you will see 2 x 8.8 kw inverters - one ECCO and the other one just normal Hybrid
August 4, 20233 yr I have not seen the ecco range for sale in SA yet. They basically fit the normal 8k into the 5k chassis, and the 5k into the 3k chassis. Mostly a cost saving, so some of the "not so important" hardware is specced lower or omitted.
August 7, 20233 yr I believe the Ecco is smaller due to colder climates not needing as big a heat-sink, hence why they're not sold here.
March 5, 20242 yr The main difference between the 2 is the application. The Ecco version can be used for marine applications and use natural cooling. It is more environment resistant, but not available in South Africa as far as I know
