AGM Batteries
12 hours ago, Johan Kotze said:
The batteries are 8 x 100ah 12v AGM. They are connected in 2 packs of 4 in series and then parallel to the inverter 48v
so 4S2P 200Ah capacity, you should probably not exceed 40A charge/discharge current and better to stick to no more than 20A, really, if you want these to live more than a few months, also, do not discharge them more than absolute maximum of 50% and ideally much less than that...
having written this, 20A at 48-odd Volt is 1kW, so, your battery capacity is waaaay too small for the inverter and don't even think of paralleling another one, unless you are planning on multiplying the current battery setup by 10 X or are planning on upgrading to Lithium 10kW battery not too far down the road...
If this is your battery    https://www.sustainable.co.za/products/vision-6fm100z-x-100ah-12v-agm-battery
then the max charge current per battery is 30A
You have 2 banks of them in parallel, so you can safely charge at 60A.  At 50A you would be on the safe side.
Suggest you also consider a battery balancer to prolong the life of the batteries  https://www.geewiz.co.za/hubble-battery-balancer/185920-lithium-48v-battery-balancer-equaliser-suitable-for-all-battery-types-24v-36v-or-48v.html  (suitable for all battery types)
Edited by zsde
56 minutes ago, Johan Kotze said:
Are there any differences between the two
There may be minor technical component changes. But the HA01, HA02 and HB02 all do exactly the same, keep the batteries balanced.
But you can always ask Geewiz for the datasheet for both, if such a datasheet exists as their site uses the same schematics of the HA02 for the HB02 as well.
Item Code:GW-A-HB02
Edited by zsde
