Bsl uneven discharge
Deon Zeelie
I needs some info on my BSL 7.2 kwh batteries that's discharging unevenly.
my system
2x7.2 bsl' 5&4 months old,connected with comms cable to each other and connected to orange Pi.
8kw Rct max connected to Pi.
16x365 w PV with all the necessary switchgear to connect the system.
Normally my system drain to around 30-40%, however on the one day it dropped from 30% to 9 % with no significant load. See Pi data below. What could cause this? Battery 2, the newer now keeps on discharging faster 2893FF0D-4745-448F-896E-03FEE83986C5.thumb.png.b1f6b0d954d5fd7330b72e3decda5ea0.png192C9FAB-9EBF-429E-B0B8-48222003CBB4.thumb.jpeg.cbb8c94781814763b56110bd1db8b602.jpeg435F4E72-FA4F-48F7-8228-60DAB8953DAA.thumb.png.c24beb9fdee34e13e025f44d929891a5.png
11 hours ago, Deon Zeelie said:
No from inverter both +&- goes to battery 1 and then jumped to battery 2image.thumb.jpg.bf5d050b7db258cde0aee4143e9ae2c7.jpg
That is probably the cause of your issue, the battery that is working harder is the with with the + & - connections to the inverter.
You need to move either the positive or negative cable to the other battery terminal (not both).
my system
Your one battery likely reached it low voltage disconnect point while the other battery was still above this level.
This will explain the sudden drop as that battery will be reporting a near 0% SOC.
Generally, while discharging the BMS will report the lowest SOC of an individual battery in the bank to the inverter while discharging (as opposed to the average SOC).
Thank you for the explanation, its a pity Solar Assistant doesn't graph the battery voltages independently, then it would be easy to confirm this. So there might be an issue with the second battery? Tonight it seems fine, will at some stage drain them to below 30% 0A7AC3F6-6D73-4068-AC73-4BB54B37EC78.thumb.jpeg.51fe4c6e246599512e7de5840a0a8bf5.jpegand see if the gap between discharge appears again
This is good news as it protects the batteries.
I only looked on Solar Assistant and it reports the average, the graph and battery tab. Opening the battery tab gives individual values but seems thats not logged (maybe wrong)
6 hours ago, frivan said:
I found that if you don't charge to 100%, the SoC becomes inaccurate. Perhaps you should discharge and charge the batteries individually to get both to 100%.
Thank yoy.The batteries weren't fully charged as we had a cloudy day. Will now keep an eye on it when it happens again and just swirch to line to complete the charge
