I made a poofee
Hi all,
You know what to do when you switch on the battery and hear a poof and smell smoke right? Just switch off and press the Undo button.
Yeah right, I wish.
I connected a Giter "48V" lithium battery to a Full Circle Solar 5kw. It's been working for months on lead acid.
I switched on using the DC breaker and then heard a clicking/sparking sound (not relay) and the inverter display is blank and switches on and off rapidly in a loop.
After the initial WTF moment I started looking at numbers and saw this...
Measured Battery Voltage 53.5V
DC input 48V
DC charger output 54V
The battery is nominal 48V and operates to 57.6V. I think it must be a 16 cell and not the usual 15 cell.
Is it possible that the voltage is too high for the inverter or was it inrush current or something else that killed it?
All I can see are some low voltage caps 16V being bulged around the 7912 (-12V) regulator.
Could the damage be limited to this or should I look further? Am I wasting time trying to repair it?
Any advice will be highly appreciated.
28 minutes ago, PsyWulf said:
You skipped the Capacitor precharge when changing to Lithium
Yes. Some battery BMSs limit the current on start-up; some just disconnect on overload. It sounds like yours is the latter.
Hence the twitching at the start. This twitching isn't good for the inverter, but you may well have gotten away with it.
Anything less than at least 60.0 V, and with many models, about 66 V, is most unlikely to be the problem.
If you pre-charge, you'll possibly find that it works just fine.
That's unfortunately common. You might as well replace some capacitors around that area while you have it open as a precaution. I recently had one of my inverters fail due to dried out capacitors, and it ended up twitching for hours when I wasn't home. That ended up damaging the solar charge controller. Recapping the power supply fixed the twitching.
What I use is an cars old ballast resister connected on series  screwed together back to back works great to charge those caps slowly and these resisters are cheap and can be bought at your local car dealers .
At less than 3 ohm IIRC there is still quite some current flowing through this kind of resistor. I prefer something around the 22 ohm value.
On 2023/06/04 at 9:35 PM, RudShep said:
Hi all,
Yeah right, I wish.
DC input 48V
Hi @RudShep whats your progress on this failure. You mentioned smoke, is that IGBTs failure?
Edited by BritishRacingGreen
