May 10, 20188 yr Hi Guys Do anyone know of an Lithium Battery that will work on the Axpert MKS Plus 3kva 24V inverter. I am in the market to replace my batteries on the Farm. Regards
May 16, 20188 yr Pylontech apparently has a list of approved inverters to work with their batteries. But I think this is irrelevant. Mine does not communicate with them - even though a communication cable is available it is not connected or used. So any 48v inverter that can charge with 52v and +25a will do.
May 16, 20188 yr 4 minutes ago, Johandup said: Pylontech apparently has a list of approved inverters to work with their batteries. But I think this is irrelevant. Mine does not communicate with them - even though a communication cable is available it is not connected or used. So any 48v inverter that can charge with 52v and +25a will do. Yes the Voltronic inverters cannot communicate with the Pylontech, but they do work.
May 16, 20188 yr Good morning everyone . With my last battery change i wanted to buy lithuim but was informed that it was not possible with the Axpert 5 kva . At the time I did not know about the Power forum . Learned a lot from u the last few months . For the future what is the way to lithium . Thanks
May 16, 20188 yr 3 hours ago, Chris Louw said: Good morning everyone . With my last battery change i wanted to buy lithuim but was informed that it was not possible with the Axpert 5 kva . At the time I did not know about the Power forum . Learned a lot from u the last few months . For the future what is the way to lithium . Thanks Hi Chris, The Pylontechs and BlueNova batteries only introduced a BMS compatible with Axpert inverters in the past 8 months or so. What to get in future? Let's see what's available then
May 16, 20188 yr The important thing is that the battery is protected if there is a low or a high cell. If the BMS has its own protection circuitry (that opens a contactor, I believe pylontech uses a large FET but I don't know), you can use any inverter that can do the required voltage levels. If anything bad happens... click, it switches off. Okay, that might not be 100% true. In some support endaevours I found some cases where battery protection kicked in and the DC bus peaked well over 65V for a few seconds. The Vickies can handle it, in fact the inverter powers the DC bus well enough that the other equipment stays up (such as the CCGX). I suspect you will blow a cap or a FET on the Axperts, if not immediately, definitely eventually. One forum member here also lost a Microcare MPPT as I recall when something similar happened. But at least you'd only blow a cheap inverter and not an expensive battery :-)
May 16, 20188 yr 1 hour ago, plonkster said: The important thing is that the battery is protected if there is a low or a high cell. If the BMS has its own protection circuitry (that opens a contactor, I believe pylontech uses a large FET but I don't know), you can use any inverter that can do the required voltage levels. If anything bad happens... click, it switches off. Okay, that might not be 100% true. In some support endaevours I found some cases where battery protection kicked in and the DC bus peaked well over 65V for a few seconds. The Vickies can handle it, in fact the inverter powers the DC bus well enough that the other equipment stays up (such as the CCGX). I suspect you will blow a cap or a FET on the Axperts, if not immediately, definitely eventually. One forum member here also lost a Microcare MPPT as I recall when something similar happened. But at least you'd only blow a cheap inverter and not an expensive battery :-) Did you know the Pylontech has reverse polarity protection? Nice, ne!
May 17, 20188 yr Unfortunately Pylontech comes only in 48V modules. So for a 24V system you would have to look further afield. It might be an idea to upgrade your inverter for something compatible.
January 13, 20197 yr Hi Andries. BlueNova has a range of batteries that are compatible with Axpert inverters for both oth 24V and 48V systems. We supply them from 24V - 77Ah - 2kWh all the way up to 48V - 65 kWh. https://bluenova.co.za/standard-range.html Regards James Edited January 13, 20197 yr by James Verster
January 13, 20197 yr Hi @James Verster, Andries ended up buying the Mini from FreedomWon. I mentioned this to you on another forum... :-)
August 12, 20223 yr On 2018/05/16 at 10:31 AM, SilverNodashi said: Hi Chris, The Pylontechs and BlueNova batteries only introduced a BMS compatible with Axpert inverters in the past 8 months or so. What to get in future? Let's see what's available then Hi Silver. Do you know if all the current Mobile Power Series (drop ins for lead acid replacement) come with onboard BMS compatible with a Voltex MKS Plus 24V 3kVA Inverter? The manual for the Axpert looks identical to this inverter so I think all from the same production line in China, different branding here.
