May 14, 20188 yr hi! i get the following partial display regarding my pv following @Coulomb&weber firmware update 73.00c, any thoughts - the readout on the icc is also attached EDIT SOLVED- it is a new functionality of the @Coulomb&weber software, hats off to the ongoing splendid products from down under! Edited May 15, 20188 yr by gabriel SOLVED
May 14, 20188 yr That is an ICC thing and not to do with the update, if you have a dual MPPT inverter then you will see [MPPT 2] come alive. I have 2 Axpert in parallel and still no [MPPT 2] numbers on this screen, howver you can view them in the [INVERTER CLUSTER VALUES] tab, which is also only available if you have parallel inverters.
May 14, 20188 yr Author 1 minute ago, pilotfish said: That is an ICC thing then why does it show only half of a panel in the lcd? it used to show a full panel, or has the lcd started failing?
May 14, 20188 yr That I dont know, will need to check with @Coulomb. Maybe it is because you have 1450W coming into a 3kW MPPT. My PV indicator is either on or off, maybe the Aussies got smarty and added power level indicator.
May 15, 20188 yr You actually have a third of a panel showing. It's like a bar graph, it will show 0, 1, 2, or 3 partial panels for around 0, 1, 2, or 3 kW of PV power. It's all in the AussieView manual. So with more sun, you'll get your full panel back. Assuming you have enough panels connected, of course.
May 15, 20188 yr AussieView Manual.txt Thanks guys... very nice functionality!! You will like this @Chris Hobson
May 15, 20188 yr 2 hours ago, Mark said: AussieView Manual.txt Thanks guys... very nice functionality!! You will like this @Chris Hobson You will like this ..... is future tense - you can apply that statement to the present tense - I do like it
