July 10, 20233 yr Hi guys. Has anyone experienced this above issue? When the grid drops and the loadshedder is activated, it would switch the devices like the geyser and pool pump off... this works fine... The issue is if the grid drops and comes back up again it switches my devices on even outside if the time parameters set... it doesn't matter if it was on or off when the grid initially dropped Is there a setting I'm missing Please help
July 10, 20233 yr change the default on power setting to off Not sure how you do it on the sonoff app, I use tasmota and it has a setting like that.
July 10, 20233 yr @DeezGP Sonoff . Select device settings. Open Power on State and select OFF and save.
July 10, 20233 yr Author Hi @WannabeSolarSparky @Chris Louw Thanks for the replies. It was set to off, but I have turned it on, and off again. I will monitor and advise if it works🙏
July 10, 20233 yr Author Evening guys... seems like it's still an issue after the above... the power on state is off on the loadshedder, geyser and pool pump... any other suggestions
July 10, 20233 yr Author I think the issue is in my scenes... I set up as per the videos but I see now there is a delay amd the device switches on when the loadshedder switches on... should I remove this
December 8, 20232 yr Hi The solution is to run your devices/schedules from scenes. When LoadShedder is "ON" then you turn "OFF" the device and "DISABLE" scene automatically with in the Load sheading scene. When LoadShedder is “OFF” you let the Recovery scene "Enable" the scenes and not the device. When the time/schedule matches a given time it will turn "ON" based on the scene pushing the device "ON" from the eWelink server. It works very well, we have this setup in over 2000 sites now and the only challenges were network issues which the Sonoff iHost has resolved. Hope this helps and if you have any questions please feel free to contact us. This was part of our original design and unfortunately may not apply to non-genuine LoadShedder due to hardware and wiring. Aleks Sonoff Africa
