May 11, 20242 yr 1 minute ago, Derek3 said: They where West Test Sets determining fault distance on Telephone lines where transposition cross over where used to calculated distance to short curcuit on Arial lines. In the good old days where 2 motion auto exchange was used, the first was in Braamfontein commissioned by SA Railways. Eish i feel so old!!! Youngsters you got no idea!!🤣🤣
May 11, 20242 yr 24 minutes ago, Derek3 said: Eish i feel so old!!! Youngsters you got no idea!!🤣🤣 I feel you @Derek3 but i can say 1 thing about the good old days these youngsters dont know about is the way things was done with integrity. I am not ashamed to say i was part of "Spoorweg" South African Railway Services" top notch in our day's.. As i remember correctly at first 1995~ Telecommunications was stationed in Braamfontein and Electrical(Dc) and Signals in Langlaagte. The training was done in Esselenpark and Koedoespoort. It was called " School of Rail" proud to have been part of it"
May 12, 20242 yr 9 hours ago, TaliaB said: I feel you @Derek3 I am not ashamed to say i was part of "Spoorweg" South African Railway Services" top notch in our day's.. As i remember correctly at first 1995~ Telecommunications was stationed in Braamfontein and Electrical(Dc) and Signals in Langlaagte. The training was done in Esselenpark and Koedoespoort. It was called " School of Rail" proud to have been part of it" One of those technical staff showed me the wiring they did . Best I have seen in my life .
May 13, 20242 yr On 2024/05/11 at 6:54 PM, Scorp007 said: The request from TaliaB was to disconnect the PV to the inverter and place a short circuit on the + and -. This test with maximum current should show varying current if there is a loose connection. Coulomb also suspect there could be some loose connection. During this test neither watch power or the inverter itself will get any PV voltage. This can only be done if you have a DC clamp meter. I am another Fluke guy with a 30 year old 73 model. May I suggest also the possibility of using a shunt resistor to measure ISC?
May 13, 20242 yr 5 hours ago, Mauritius B said: I am another Fluke guy with a 30 year old 73 model. May I suggest also the possibility of using a shunt resistor to measure ISC? Yes a method I have used a lot for about over 8A. Don't like too high currents with voltage drop through me leads. My favourite is 2 brass screws on the lid with the sjunt inside the enclosure.
July 3, 20242 yr Author For the record, the resolution to this problem was a firmware update from Segen Solar. Rather frustrating waste of time. Thank you all for your help. I (foolishly) assumed that on checking their firmware upgrade site was out of action that they would at least be shipping new inverters up to date or close to. As a btw: When we tried the solar panel test, not sure what went wrong but when we flipped the fuse off it failed/caught fire. Edited July 3, 20242 yr by martinmcg
