Mixing JA Solar Panels 550w and 540w
CTskollie
Hi All
I believe it's fine but thought let me rather confirm with you wise people, can I mix 550 JA Solar and 540W panels from the same line.
The specs of the panels are as below,  I want to add 6 550w panels to my existing 8 540w panels.
it's currently connected 4 panels on each string and I'm thinking of adding 3 panels to each string. Will thus total 7 panels of each string.
It's connected to an 8kw Sunsynk inverter, see panel specs below. Thank you guys.
1 hour ago, CTskollie said:
Hi All
It won’t be a problem just keep in mind the 550w panels will become a 540w panel as the Imp of the 550w panel will not be 13.11A but will become 12.97A. Very little difference but a difference nevertheless.
2 minutes ago, GreenFields said:
Would it be a big deal to transfer the 8 existing 540W panels onto one string on MPPT1, and put all the 6 new panels in series on MPPT2?
In the end the difference is small, but it could add up to just over 100kWh per year.
Luckily I saw your post as I was going to go as you indicated. Saved some typing. 😃😃
Thank you all for the responses, I thought it should be fine but just wanted to make sure.
I still need to get the new panels installed so when I install then it may be an option to move the 8 on one string and the 6 on the other. I don't mind losing the 10w though, the 14 panels as it is is way above what I need. I'm just adding panels as pricing is great right nw and the extra panels is for the winter months.
In ssummer the 8 panels was adequate as is but thinking of installing aircons so a win either way.
You need to confirm if your installer used Mppt1 4s2p and left Mppt2 open. Then you can install the 6 x 550w run 1 string to mppt2 into string 1 input. Remember these mppt's have 2 string inputs/ mppt.
If you go with 7x mixed panels you will lose 60w x 5.5(winter sun hours) x 365 = 120.45kwh/ year as @GreenFieldssuggested. The choice is yours i am only advising.
Edited by TaliaB
Tech question: Is this not the maximum theoretical amount you could lose? The panels are only running at max output part of the day...
I would in any case rather add the new ones onto their own string. Makes it easier to maintain, compare, fault find etc..
 The reason i used 5.5h in my calculation in summer you would get around 6.5h location specific so i think for the purpose of this exercise it would be pretty close. Yes agree with seperate string for the 550w.
Edited by TaliaB
For an answer the lower current panel will throttle during the whole day the way I see it.
May be the way @TaliaB calculated taking the days full production is spot on.
Yes you are quite correct in essence the 550w panel becomes a 540w panel due to lower Imp flowing in the 540 panel and they are series connect in a string.
My reply was based on say at 09h the 550 can produce 400W @X amps the 540W  would produce less amps and still throttle.
Thank you all for the replies, i checked and its currently installed 4 panels on MPPT 1 and 4 on MPPT 2.
I guess it won't be that hard to move the 8 550w panels to MPPT 1 and the 6 on MPPT 2 so will go with that option, 120kwh is quite a lot of Kwh to go to waste.
Thank you all again for the input, hopefully new panels will come this week and installed by next week.
