Frodo Posted March 10, 2019 Share Posted March 10, 2019 Hi, We installed a new Infinisolar Super 4k. epIt was running fine for about a week, but then Today at around 13h tripped and reported Error 12. Reset it, and it was runnng fine, although picked up PV input slowly. Any ideas what could have caused it and possible solutions? Quote Link to comment Share on other sites More sharing options...
Youda Posted March 10, 2019 Share Posted March 10, 2019 Manual says "leakage current": http://www.fullcirclesolar.co.za/wp-content/uploads/2017/05/FCS-InfiniSolar-Super-4KW-manual.pdf It's related to the DC side - PV modules and wiring. Normally, this error shows up when you have one of the poles (negative or positive) of the solar array grounded. Infini is not galvanically isolated, thus there must be no grounding of negative, nor positive pole. Grounding negative pole of the solar array is someting what's done when amorphous panels are used. They need negative pole grounding in order to protect them from PID degradation. Check the impedance of negative/positive pole of the solar array against earth. There might be a shunt or faulty solar module. Quote Link to comment Share on other sites More sharing options...
Frodo Posted March 11, 2019 Author Share Posted March 11, 2019 Thank you. Quote Link to comment Share on other sites More sharing options...
Frodo Posted April 9, 2019 Author Share Posted April 9, 2019 Hi, All cabling checked twice, and the panel's frame earthing amended. Also tested all panels and can't pick-up anything abnormal. Still getting the Error 12 every now and then, sometimes it remains in Error 12 state for the rest of the day, sometimes it can be reset? Any ideas would be appreciated? Thanks! Quote Link to comment Share on other sites More sharing options...
Coulomb Posted April 10, 2019 Share Posted April 10, 2019 3 hours ago, Frodo said: Also tested all panels and can't pick-up anything abnormal. Does that include checking for leakage from positive and negative PV wires to frame? With multimeter or megger? Quote Link to comment Share on other sites More sharing options...
Frodo Posted April 10, 2019 Author Share Posted April 10, 2019 We tested with a multimeter. What can cause a leakage to the frame? Quote Link to comment Share on other sites More sharing options...
Coulomb Posted April 10, 2019 Share Posted April 10, 2019 (edited) On 2019/04/10 at 1:47 PM, Frodo said: We tested with a multimeter. I think that's not good enough for panels; there could be a leakage to frame anywhere in the 60-72 cells, and away from the terminals, you have a set of (light sensitive) diodes in series. The ~3 V of the multimeter would only forward bias half a dozen cells, so you won't "see" beyond nearest dozen. I assume you at least tested in both directions (polarity of multimeter leads) for both ends of each panel. On 2019/04/10 at 1:47 PM, Frodo said: What can cause a leakage to the frame? I have no idea of the cause; my panels are all ELV, so I don't even bother earthing the frames. I guess it has to be moisture ingress. Can you perhaps see any cracks in the glass, perhaps from hail? Edited March 14, 2021 by Coulomb Quote Link to comment Share on other sites More sharing options...
Frodo Posted April 13, 2019 Author Share Posted April 13, 2019 Hi, No, there is no visible damage or moisture visible on visual inspection of the panels. Thanks, Quote Link to comment Share on other sites More sharing options...
Nicholas Posted April 21, 2019 Share Posted April 21, 2019 I've seen spurious Error 12's on the Infini 4K. Try a firmware update (You'll need to ask your original equipment supplier), it's worked for me a couple of times. Quote Link to comment Share on other sites More sharing options...
Green Bum Posted March 13, 2021 Share Posted March 13, 2021 Hi Frodo, have you managed to solve your Code 12 error? I am having a similar problem after 4 years.. my error 12 appears with strong sun around noon and about 75% load, after a few beeps (safe mode) it switches back to solar feeding load. Quote Link to comment Share on other sites More sharing options...
stoneyc113 Posted May 14, 2021 Share Posted May 14, 2021 On 2021/03/13 at 4:15 PM, Green Bum said: Hi Frodo, have you managed to solve your Code 12 error? I am having a similar problem after 4 years.. my error 12 appears with strong sun around noon and about 75% load, after a few beeps (safe mode) it switches back to solar feeding load. Hi any success? My experience is exactly as you described. Being going on for more than a year. Some days nothing. Quote Link to comment Share on other sites More sharing options...
Green Bum Posted July 13, 2021 Share Posted July 13, 2021 Hi sorry for the delay..... Yes I sorted the problem by cleaning the air vents at the top of my inverter using a vacuum cleaner... I also opened the inverter and used a blower to clean the inside.... Problem solved Hope this helps! Quote Link to comment Share on other sites More sharing options...
Sajid878 Posted April 8 Share Posted April 8 (edited) Have anyone success in resolving the error 12? I have Infinisolar E 5.5 kw and facing same error 12 problem, the error Popup in the morning as Sun rises or in the evening when Sun goes down, rest is okay. Some times the error resets by its own and some times I have to reset it manually and setting the battery charging from utility. Please anyone could help. Thanks in advance! Edited April 8 by Sajid878 Quote Link to comment Share on other sites More sharing options...
