Integrating Solis PV inverter with an existing Sunsynk system
I'd like to know whether it is possible to integrate a Solis PV inverter (S5-GC25K for example) with an existing Sunsynk system (2 x 12kW 3ph inverters in parallel, 3 x 10kWh Sunsynk batteries)?
*Theoretically* it should as it's Grid-tied if it's not too iffy about its grid-source
Yes It can work you will have to use a Solis 3 Phase grid tied inverter something like a 20KW and couple it to the genport in 3 phase you will need to activate micro inverter input however the maximum you can input would be 50% of your system capacity and you would have to make sure that the genport inputs on the Sunsynk's are in parallel and the max PV can then be 12KW that would be attached to the Solis 20KW grid tied inverter.
