Infinisolar 3k plus Factory Password
  • Replies 72
  • Views 22.7k
  • just understand that the minute you access that area for advanced settings, you void your warranty..
  • No. It just depends on how long the unit has been stored in a warehouse, either in China or with your reseller, or both. Voltronic Power used to be great with making all the latest firmware updat
  • Hi , Hernancalcagno  and others that may have the 50.1 Hz issue with Infinisolar , The way I resolved it was after a deep dive into the setting I found that: If you Enable Wide AC input ran
Would this limit only feed-in to grid or total output of inverter? I want to limit feed-in to grid to 5KW but keep inverter total output at 10KW - so I can run heavy load and get full PV output. But restrict feed-in to grid to 5KW to avoid legal issue with utility/grid.
Edited by LionKing
Depends on the setup:
First of all, the firmware hast to be up to date - there were many bugs in relation to feed-limits.
You need a smartmeter (SDM630 Modbus) and a modbus-card off course.
Configuration (solarpower) has to be adapted.
The inverter already knows, how much its sending to the grid. Wouldn't the max feed-in to grid setting just work without smartmeter? Can I just set upper limit of power generated by PV?
Never tried that - but it should not be a big deal to test that out:
Limit grid power to 1kW and also battery charge amps to e.g. 20A. If your solar power exceeds 1000W charge power (~50V/20A) the rest should be sent to grid.
What happens if your solar energy exceeds 2000W? Does the inverter throttle the solar energy?
I am able to change this setting. Are you sure it only limits Power generation/export of Inverter? If I set it to 5KW, would load on inverter still be able to pull 10KW from grid?
No, did not consider LOAD at all.
You have to test it out with the procedure described above, keeping also an eye on your load.
This is a very special setup, never tried this with the 10k.
Was the max feed-in to grid setting removed from newer software version, if so, where can i get older software version ? or does it only show-up if the inverter firmware supports it?
FW is a good one, but probably not the latest for your inverter. What's the serial# of your machine?
Anyhow, take a pretty new solarpower1.22Sp7 for configuring.
Does this version show Max feed-in setting for you? what if I use an older version e.g. SolarPower v1.14SP8 from 2020/8/11, its closer to the inverter firmware date?
I see the option in older version, however, after reading the manual again I think max feed-in setting only works if Grid-Tie with Backup (III) is selected. I'm going to try it now.
Yes, off course.
22 hours ago, riogrande75 said:
Yes - afaik you need this password to set a limit with SolarPower:grafik.png
Do you know what this thread is all about? 😁
Edited by riogrande75
I meant its asking for factory password even for Max. feed-in grid power setting. What's the factory password? My inverter is 8 years old and the white-label company that sold it to me is gone now.
Dear i Have problem in my inverter when grid feed is on the its not charge the battery with solar and grid both and if i stop grid feeding then its working fine please guide me on it
