Infinisolar 3k plus Factory Password
  • Replies 72
  • Views 22.7k
  • just understand that the minute you access that area for advanced settings, you void your warranty..
  • No. It just depends on how long the unit has been stored in a warehouse, either in China or with your reseller, or both. Voltronic Power used to be great with making all the latest firmware updat
  • Hi , Hernancalcagno  and others that may have the 50.1 Hz issue with Infinisolar , The way I resolved it was after a deep dive into the setting I found that: If you Enable Wide AC input ran
On 2020/01/14 at 5:38 PM, Chema said:
Dear Mike,
Can i have the factory password, thanks in advanced
Best regards
Try "administrator"
On 2017/02/20 at 7:02 PM, SilverNodashi said:
Hi,
Please PM me the password as well?
Hey there, is it possible for you to provide me, with the 'factory password' as well ?
Thx in advance !
Kind regards
Smirnoffdk
On 2020/02/02 at 8:42 PM, ETC said:
Try "administrator"
‘Administrator’ is the standard password, but there are certain special setting, that only can be changed, if you got that ‘factory password’ the reason it’s not in the manual, is that you can actually destroy your inverter, with the wrong setting ! So caution is advised!
Hello! Can you also send me the "factory password" ? I want to look in the parameter setting (the settings that aren't shown up in the standard log in) because my Infini Solar 3kw won't switch back to PV and Battery if Overload.In the evening the grid it charges the batteries from the grid or it uses only grid power, even if batteries are 80% full (I have 4 x200A 12V gel batteries). So mainly it doesn't switch back automatically to PV and batteries from grid power in Offgrid mode. I understand that it should take from the grid  only if the load exceeds the PV and Battery capacity.
Thank you in advance.
As stated many times, the inverters itself do not have a password - only SolarPower software wants one when changing major settings.
The password can be found in this manual hys-3000-ba-de-neu  on page 16, right after the word "Werkspasswort".
It is also posted here: infinisolar-3kw-plus-factory-password in the last post.
This is valid and working on all voltronic invertes that get configured with solarpower.
I need the factory password too for my Infinisolar E 5.5KW to lower the "max feed in grid power" from 5.500W to 3.600W because the wire from the inverter to the main main surge protection box is just for 16amps = 3.700W
Would  be very helpfull if somebody PN me the password.
Thanks very much
Hi , EngHomam You will loose Warranty if you change something and it breaks your inverter ,  (  And even if your inverter fails for another reason it will not be covered ,)
What setting or why do you want to change , that needs the factory password ,
I could help you with normal parameters to get past your problem , if i new what it was ?
  • 1 year later...
On 2021/12/12 at 6:32 PM, Sajid878 said:
Please anyone send factory password on [email protected]
Thanks!
HI You could try this ( no warranty if you use it )
Werkspasswort "zAxE12_ObB8ya"
  • 9 months later...
  • 3 months later...
I think factory password is just problem of PC application. There is no password in communication protocol. If you set everything by sending commands nobody can tell you that you overcome some factory password. I control inverter only this way. Original software seems to do what is not expected. For example if you change one voltage it changes also others or it might just modify values in app not in invertor but in any case it is not reliable behaviour. The commands on serial line are much safer. You change only what you really want to change.
  • 7 months later...
  • 1 year later...
You helped me a lot dude. Thank you so much ! I'm going to come over there and kiss you!
  • 3 months later...
  • 10 months later...
Do I need factory password to view/change "Max feed-in to grid power" setting on Infini 10KW 3P? I need to reduce the feed-in power to grid. With administrator password in SolarPower, I'm not even seeing that parameter setting.
