February 16Feb 16 I have a dual Victron Multi II 3kva setup with 250vMPPT and a stack of pylons. I recently purchased a house and will lily have the opportunity to move my setup before my previous house sells. The new house has a sunsync 5kw. I am seriously considering taking my existing setup and just swapping it. Any ideas/Suggestions? Existing setup is mounted on a wooden panel so should be "fairly" simple to swap.
February 16Feb 16 31 minutes ago, JTK said:I have a dual Victron Multi II 3kva setup with 250vMPPT and a stack of pylons. I recently purchased a house and will lily have the opportunity to move my setup before my previous house sells. The new house has a sunsync 5kw. I am seriously considering taking my existing setup and just swapping it. Any ideas/Suggestions? Existing setup is mounted on a wooden panel so should be "fairly" simple to swap.You don't mention the most crucial part - the solar panels 🙂
February 16Feb 16 Author wont be taking the panels with. I have 12 550's and new house 6. 550's. I will just add another 6 there...
February 16Feb 16 This amounts to whether you should swap the Victron kit for the Sunsynk. This will give you an extra 2kW on the backed up side. Do you have a particular preference for the Victron gear? What's the situation with batteries? You have those where you are now, but at the new place?
February 16Feb 16 2 hours ago, JTK said:I have a dual Victron Multi II 3kva setup with 250vMPPT and a stack of pylons. I recently purchased a house and will lily have the opportunity to move my setup before my previous house sells. The new house has a sunsync 5kw. I am seriously considering taking my existing setup and just swapping it. Any ideas/Suggestions? Existing setup is mounted on a wooden panel so should be "fairly" simple to swap.For me, it goes without saying , I would swap the system.The resale and long-term value of two 3kva Victron MultiPlus-II units combined with a Victron 250V MPPT is significantly higher, and in my experience, so is the overall build quality.Running the two MultiPlus-II units in parallel also gives you more available output power than a single 5kW Sunsynk. On top of that, you gain true redundancy , two inverters instead of one. If one unit has an issue, the system can continue operating at reduced capacity rather than going completely offline. From both a quality and system design perspective, it’s a stronger setup.
February 16Feb 16 Author thanks. yes also feel I want to take it (victron kit) with. I am comfortable with my setup. its never failed. been running a long time and just does its thing...
February 16Feb 16 Author 1 hour ago, Bobster. said:This amounts to whether you should swap the Victron kit for the Sunsynk. This will give you an extra 2kW on the backed up side. Do you have a particular preference for the Victron gear? What's the situation with batteries? You have those where you are now, but at the new place?I have the batteries where I am now. WIll want to take them with. If not all of them maybe just two UP5000's. can always add again to that. that will leave 3 us3000's
February 22Feb 22 Victron system is superior in terms of reliability, durability and efficiency.They are hardly affected by poor grid, weather or inferior electrical appliancesThey will last longer. Very long.. Have one inverter thats been running since 2011 at my parents placeSelf power consumption is also very very low compared to sunsynk. My 8kw Sunsynk would use max 71watts whilst now my 2 x multis 2 5kva use just 37watts.
February 22Feb 22 1 hour ago, Jakac said:Victron system is superior in terms of reliability, durability and efficiency.They are hardly affected by poor grid, weather or inferior electrical appliancesThey will last longer. Very long.. Have one inverter thats been running since 2011 at my parents placeSelf power consumption is also very very low compared to sunsynk. My 8kw Sunsynk would use max 71watts whilst now my 2 x multis 2 5kva use just 37watts.Surely 34W standing load on a 8kW system that can on average over a year produce 40kWh a day(Gauteng) is counting the last cent in the wallet every day.
March 17Mar 17 Author OK. I am going to leave the systems where they are and just add to the new installation... To many things that can go wrong during removals and swaps etc..
March 17Mar 17 31 minutes ago, JTK said:OK. I am going to leave the systems where they are and just add to the new installation... To many things that can go wrong during removals and swaps etc..Just get an electrician to remove the equipment and install it at the new place. Nothing can go wrong. Just isolate the breakers/isolators and remove them. The panels can stay VOC and wont care.
