Configuration / setup software for Carlo Gavazzi ET112
Hi,
I must be blind, but where do I download the config / setup software for the ET112 energy meter?
Victron says its free on the Carlo Gavazzi web site but really I can’t find it.  By now I’m not even sure which web site IS the official Carlo Gavazzi site.
I want to check my cabling is right and set it up and change its RS485 address so I can put it on the same bus as my Pylon batteries.
Thanks!
Nothing to download / config. Plug and play with the VenusGX.
"Universal Configuration Software" which seems to be the right thing.
Sorry, cannot help there. 🙂
My understanding is that through the software you are able to assign a new address to me meter.
Without it only the meter version with the screens can be assigned a non-default address manually.
I think this overcomes the Venus issue, so now more than one meter can be on the same 485 bus.
Otherwise, only one meter/bus in Venus as all meters start with the same default address and conflict.
Indeed, dbus-cgwacs automatically sets it up if it isn't correctly configured yet. But Elbow doesn't have one of these...
Carlo Gavazzi's site is not the most logical place on the internet... I managed to find te software once... let's see if I have success again...
(... some time passes ...)
OK, so you go to https://www.gavazzionline.com
Information -> Software and Manuals
Energy Management
Universal configuration software (ucs.zip).
Definitely not the easiest thing to find...
Edited by plonkster
Energy Management
Thanks.
Well I successfully connected, then using the app changed the baud rate to 115200 to match my other rs485 devices and now I can’t connect for love nor money...
Emailed them for advice.
And if I may interject here with a question of my own 😉  ET112 to be installed in main db one day - but venus device lives in garage about 15 meter away.  What is the best way to connect?  I looked at the suggested zigbee devices - but they are *not* cheap...  Also - then I'd have to have a power supply close to the db etc.
Well I just pulled cat5e.  Rs485 can go a long way.
otoh right now it’s not working...
Mine (actually the EM version) is over 30 meters from the Venus device, works fine using the Victron 485 to USB converter, extended using Cat5.
5 hours ago, phil.g00 said:
120R?
Yes - at the meter end you put a bridge between pins 3 and 5 to connect an internal terminating resistor.  At the PC end I used a resistor.
Some RS485-USB devices already have a terminator. That might well be why it doesn't work at higher speeds... your bus is over-terminated 🙂
It's not that.  I checked the resistance across the A/B pins on the adapter with the resistor connected and it was 120 ohms.
Maybe the problem is my RS232/485 adapter, or that combined with the USB/serial.  My other FTDI based adapter doesn't work - presumably a victim of the FTDI clone chip infowars.  So I'm trying to get another.
Wish I could find out how to factory-reset the ET112 to get it back to 9600 baud.
Get one from a Victron shop 🙂 Those are known to work properly and have real FTDIs in them.
Pointer to where?  thepowerstore is out of stock.
Did you found one?
8 minutes ago, The Terrible Triplett said:
Did you found one?
Not yet. I emailed 3 suppliers this morning, no reply yet.  Sonop web site says they have but not first choice cos its mail order.
I’ll try chase up tomorrow.
  • 6 years later...
