The dreaded Revov's on Sale!
23 minutes ago, shanghailoz said:
Canbus over RS485<-> to a Ve.direct usb adaptor
Nice. If you know where to get the communications protocol specs from the supplier then my software driver should be able to do this as well. At the moment it is only working with 1 BMS brand, but if there are people with other batteries that we can get the commands for it would be great to add to the driver.
What information does the Canbus over RS485 cable give you. What values are coming through from the BMS?
If you go to the details of your battery in your Remote Console for your VenusPi what values does it give you compared to the first 3 pictures in my post here
  • Replies 94
  • Views 36k
  • Right, let me inject a bit of sanity into the "dreaded" (most likely not meant in a bad way) claim. Way back some BYD batteries came into the country and were sold at ridiculous prices, by a comp
  • And a other thing is, that's maybe a good thing, this will make a bit of competition in the local SA market that the other guys can drop on there price.
I won't lie, I've been watching your post with interest already 😀
The "RCU" BMC doesn't push much data over to the Victron - looks like a bare minimum.
i.e. Voltage, Amps / Watts / SoC.
The PC based BMS software can drill down to battery state, and see other details.
I'll need to organize a cable then do some digging to see whats available from the BMS itself.  I don't have a copy of their data sheet, but worst case can sniff.
I have a ton of RS232 -> USB but no 485's! here.  I also don't have any tools this side - all my goodies are back in China, so will need to buy some bits n bobs :(
and with some draw -
Definitely bare minimum - as none of the other data is populated eg
Edited by shanghailoz
This means the data is available. That cable just does not publish it. The basics is all that is required, but the rest is very nice to have.
but no 485's! here
I can confirm that this one does work with the VenusOS Pi. The drivers are already available and loaded.
Most suppliers will send this if you ask them. Just try sending a few mails. It much easier that trying to sniff commands if you have the spec.
Yes, I was pointing out the same thing 😃
That cable is out of stock, I did look already.
I haven't bothered asking yet, given the few data points I don't think will be too hard to plumb the depths of the protocol!
This one use the same chip and should work as well.
This HAT is also confirmed to work by one of the forum users. You do need to edit the config file for the Pi to load it though and I don't know if the HAT will work with the serial-starter that the VenusOS use.
  • 1 year later...
Revisiting this a few years later!
Have downloaded your script, need to see how to get it to work.
I have 3 devices connected to my PI.  2 x Victron cables + an RS485 cable.
The modbus adaptor seems to be on usbtty0 (after grepping dmesg to see where it got populated)
lsusb
Bus 001 Device 006: ID 0403:6015 Future Technology Devices International, Ltd Bridge(I2C/SPI/UART/FIFO)
Bus 001 Device 005: ID 0403:6015 Future Technology Devices International, Ltd Bridge(I2C/SPI/UART/FIFO)
Bus 001 Device 004: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
Unplugging/plugging in confirms thats correct.
udevadm info --query=property --name=/dev/ttyUSB0
DEVLINKS=/dev/serial-starter/ttyUSB0 /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AC00XXY2-if00-port0 /dev/serial/by-path/platform-3f980000.usb-usb-0:1.2:1.0-port0
DEVNAME=/dev/ttyUSB0
DEVPATH=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/ttyUSB0/tty/ttyUSB0
ID_BUS=usb
ID_MODEL=FT232R_USB_UART
ID_MODEL_ENC=FT232R\x20USB\x20UART
ID_MODEL_FROM_DATABASE=FT232 Serial (UART) IC
ID_MODEL_ID=6001
ID_PATH=platform-3f980000.usb-usb-0:1.2:1.0
ID_PATH_TAG=platform-3f980000_usb-usb-0_1_2_1_0
ID_REVISION=0600
ID_SERIAL=FTDI_FT232R_USB_UART_AC00XXY2
ID_SERIAL_SHORT=AC00XXY2
ID_TYPE=generic
ID_USB_DRIVER=ftdi_sio
ID_USB_INTERFACES=:ffffff:
ID_USB_INTERFACE_NUM=00
ID_VENDOR=FTDI
ID_VENDOR_ENC=FTDI
ID_VENDOR_FROM_DATABASE=Future Technology Devices International, Ltd
ID_VENDOR_ID=0403
MAJOR=188
MINOR=0
SUBSYSTEM=tty
USEC_INITIALIZED=3679573
If I tail the serial logs I can see that its trying to assign a driver repeatedly.
tail -F /data/log/serial-starter/current  | tai64nlocal
2022-05-02 09:38:00.441561500 INFO: Start service dbus-serialbattery.ttyUSB0 once
2022-05-02 09:38:09.701031500 INFO: Start service gps-dbus.ttyUSB0 once
2022-05-02 09:38:18.973991500 INFO: Start service vedirect-interface.ttyUSB0 once
2022-05-02 09:38:24.202539500 INFO: Start service dbus-cgwacs.ttyUSB0 once
2022-05-02 09:38:29.425260500 INFO: Start service dbus-fzsonick-48tl.ttyUSB0 once
2022-05-02 09:38:32.627069500 INFO: Start service dbus-imt-si-rs485tc.ttyUSB0 once
2022-05-02 09:38:35.840616500 INFO: Start service dbus-modbus-client.serial.ttyUSB0 once
2022-05-02 09:38:39.047054500 INFO: Start service dbus-serialbattery.ttyUSB0 once
2022-05-02 09:38:48.313591500 INFO: Start service gps-dbus.ttyUSB0 once
2022-05-02 09:38:57.578868500 INFO: Start service vedirect-interface.ttyUSB0 once
2022-05-02 09:39:02.803860500 INFO: Start service dbus-cgwacs.ttyUSB0 once
If I check the serial-starter.conf
cat /etc/venus/serial-starter.conf
service cgwacs dbus-cgwacs
service gps gps-dbus
service modbus dbus-modbus-client.serial
service modem dbus-modem
service mkx mk2-dbus
service vedirect vedirect-interface
service fzsonick dbus-fzsonick-48tl
service imt dbus-imt-si-rs485tc
alias rs485 cgwacs:fzsonick:imt:modbus
alias default gps:vedirect
include /data/conf/serial-starter.d
I see that there is already a rs485 set of drivers?
Should I disable those?
cat /data/conf/serial-starter.d
service sbattery dbus-serialbattery
Does show sbattery added (i assume this is what you've called the service)
Looking at the logs
root@raspberrypi2:/opt/victronenergy/dbus-serialbattery# tail /var/log/dbus-modbus-client.ttyUSB0/current  -F | tai64nlocal
2022-05-02 09:44:23.410207500 /opt/victronenergy/serial-starter/run-service.sh: line 5: shift: 2: shift count out of range
2022-05-02 09:44:24.661635500 INFO     Waiting for localsettings
2022-05-02 09:44:24.686419500 INFO     Starting background scan
2022-05-02 09:44:24.688038500 INFO     Scanning ttyUSB0 @ 38400 bps (quick)
2022-05-02 09:44:26.005016500 INFO     Scan complete
2022-05-02 09:45:02.054384500 /opt/victronenergy/serial-starter/run-service.sh: line 5: shift: 2: shift count out of range
2022-05-02 09:45:03.259235500 INFO     Waiting for localsettings
2022-05-02 09:45:03.283734500 INFO     Starting background scan
2022-05-02 09:45:03.285313500 INFO     Scanning ttyUSB0 @ 38400 bps (quick)
2022-05-02 09:45:04.602015500 INFO     Scan complete
I see an error with the run-service.sh script.
normal?
You think the best way will be to take one of the existing BMS in your script and modify for the relevant modbus addresses?
I have the data sheet for the BMS attached.
REVOV.Modbus.communication.protocol.v1.pdf
The modbus docs appear to be utterly incorrect.
Had a bit of a play using the manual modbus registers, and no luck, so opened up the BMS software and did some serial sniffing instead.
Of course the address is not at 01 that would be too easy,  seems to be using 0x7C (124).
Having fun though, hopefully I can hack together a revov "tianpower" driver.
Either I'm doing something wrong (or its just not modbus).
[Narrator: It wasn't modbus, its modbus"ish", gah!  :)]
Some command data samples
7C 01 33 00 FE 0D ->  Get name.  Returns
7C 01 33 Length + [data] + checksum? + endline (0xd)
eg
7c 01 33 16 54 50 2d 42    x x x x T P - B
44 31 36 53 34 38 56 31    D 1 6 S 4 8 V 1
35 30 2d 56 33 2e 31 2e    5 0 - V 3 . 1 .
32 39 e2 0d                2 9  [crc?]  [newline]
TP-BD15S48V150-V3.1.29
7C 01 42 00 80 0D -> Get Model Number. Returns
7C 01 42 0F 54 42 4D 31      x x x [length] T B M 1
39 30 34 31 33 30 30 32     9 0 4 1 3 0 0 2
36 33 20 8C 0d                     6 3 [crc?] [newline]
Quote
2022-05-02 16:28:57.625069500 ERROR:SerialBattery:Revov::False
2022-05-02 16:28:57.625493500 ERROR:SerialBattery:Data is False
2022-05-02 16:28:58.126764500 WARNING:SerialBattery:Testing Revov
2022-05-02 16:28:58.167072500 ERROR:SerialBattery:serial data length 22
2022-05-02 16:28:58.167507500 ERROR:SerialBattery:lc-1
2022-05-02 16:29:14.089183500 ERROR:SerialBattery:bytearray(b'|\x01B\x0fTBM19041300263 \x8c\r')
2022-05-02 16:29:14.089602500 ERROR:SerialBattery:>>> ERROR: No reply - returning (count>150)
2022-05-02 16:29:14.090844500 ERROR:SerialBattery:b'|\x01B\x00\x80\r'
Starting to take shape.   Have some debugging up to see the passed result within the serial driver code although  the python read_serial_data that @Louisvdw has isn't commented that well.
Need to work out what LENGTH_POS, LENGTH_CHECK are as its not that obvious in utils.py code
LENGTH_POS should be the start offset - at least looking at the code, although if i change it, I don't see my data changing.
LENGTH_POS is the offset starting from 0 bytes for packet length.
PACKET_LENGTH might be a bit more obvious imho.
LENGTH_CHECK not quite sure yet.
At least its talking and giving back a response, even though I need to get the returned values to work correctly with the read_serial_data(command, port, baud, length_pos, length_check, length_fixed=None, length_size=None) function.
Quote
2022-05-02 18:11:13.686966500 WARNING:SerialBattery:dbus-serialbattery v0.1
2022-05-02 18:11:13.687686500 WARNING:SerialBattery:Testing Revov
2022-05-02 18:11:13.827072500 ERROR:SerialBattery:Revov TP-BD16S48V150-V3.1.29
2022-05-02 18:11:14.004604500 ERROR:SerialBattery:Revov ver ( TBM19041300263 )
2022-05-02 18:11:14.005181500 WARNING:SerialBattery:Connection established to Revov
Getting further.  Have worked out what it was trying to do.
    LENGTH_CHECK = 0
    LENGTH_POS = 3  #offset starting from 0 byte for packet length
    LENGTH_FIXED = -1
Works out.
I can now call and read 2 settings.
command_get_version = b"\x7C\x01\x42\x00\x80\x0D"  #Get version number
command_get_model = b"\x7C\x01\x33\x00\xFE\x0D" #Get model number
Will work a bit further tomorrow.  I need to sniff some more serial to see what it needs to query cells and other values.
Happy with todays progress though.
I'm using logger.error for my current output (hence the "error serial" above, as logger.info doesn't display in the logs).
Some more work to get the driver loaded (fake hard coded data!), but its appearing now in the Victron side.
My logs looking good too
2022-05-02 19:16:58.577040500 WARNING:SerialBattery:dbus-serialbattery v0.1
2022-05-02 19:16:58.577708500 WARNING:SerialBattery:Testing Revov
2022-05-02 19:16:58.638016500 WARNING:SerialBattery:Modbus Address: 124
2022-05-02 19:16:58.638502500 WARNING:SerialBattery:Modbus Type   : 1
2022-05-02 19:16:58.638950500 WARNING:SerialBattery:Modbus Command: 51
2022-05-02 19:16:58.639399500 WARNING:SerialBattery:Modbus PackLen: 22
2022-05-02 19:16:58.639836500 WARNING:SerialBattery:== Modbus packet good ==
2022-05-02 19:16:58.640329500 ERROR:SerialBattery:Revov TP-BD16S48V150-V3.1.29
2022-05-02 19:16:58.787653500 WARNING:SerialBattery:Modbus Address: 124
2022-05-02 19:16:58.788143500 WARNING:SerialBattery:Modbus Type   : 1
2022-05-02 19:16:58.788595500 WARNING:SerialBattery:Modbus Command: 66
2022-05-02 19:16:58.789043500 WARNING:SerialBattery:Modbus PackLen: 15
2022-05-02 19:16:58.789478500 WARNING:SerialBattery:== Modbus packet good ==
2022-05-02 19:16:58.789910500 ERROR:SerialBattery:Revov ver ( TBM19041300263 )
2022-05-02 19:16:58.790313500 WARNING:SerialBattery:Connection established to Revov
2022-05-02 19:16:58.837810500 WARNING:SerialBattery:Battery connected to dbus from /dev/ttyUSB0
Slowly slowly!
This one is actual data pulled from the hardware (not hard coded)
Hardware version is being populated correctly :)
revov.py
Code so far
In order to test, will also need to be added into dbus-serialbattery.py  by adding
(under import logging line )
from revov import Revov
and in the battery_types array add another line for
Revov(port=_port, baud=9600),
This is a work in progress
This only loads the driver so far, and shows the Hardware revision and Hardware version data.
Some data is hard coded so that the driver loads successfully.
These vars -
        self.soc =70
        self.voltage = 52.7
        self.current = 6
        self.cell_min_voltage = None
        self.cell_max_voltage = None
        self.cell_min_no = None
        self.cell_max_no = None
        self.cell_count = 16
Victron Side will display:
Two more commands
 command_one = b"\x7C\x01\x06\x00\xF8\x0D" #returns 4 bytes
2022-05-02 20:08:48.202980500 WARNING:SerialBattery:bytearray(b'|\x01\x06\x04\x00\x00\x0e\xa6')
[ 0x7c 0x01 0x06 ] [ 0x04 ] [0x00 0x00 0x0e 0xA6] [ 0xec]  [0x0d]
[Modbus addr/reg/cmd]  [length] [ data 0x0 0x0 0xe 0xA6] [Checksum?] [LF]
2022-05-02 20:08:48.204063500 WARNING:SerialBattery:Modbus Address: 124
2022-05-02 20:08:48.205698500 WARNING:SerialBattery:Modbus Type   : 1
2022-05-02 20:08:48.205704500 WARNING:SerialBattery:Modbus Command: 6
2022-05-02 20:08:48.206214500 WARNING:SerialBattery:Modbus PackLen: 4
2022-05-02 20:08:48.206727500 WARNING:SerialBattery:== Modbus packet good ==
command_two = b"\x7C\x01\x01\x00\x02\x0D" #returns a ton of data (118 bytes) eg
2022-05-02 20:08:48.532293500 WARNING:SerialBattery:bytearray(b"|\x01\x01v\x01\x10\x0c\xf1\x0c\xf5\x0c\xf5\x8c\xf4\x0c\xf2\x8c\xf2\x0c\xf4\x8c\xf5\x0c\xf2\x0c\xf2\x0c\xf6\x0c\xfa\x0c\xf4\x0c\xf4\x0c\xf6\x0c\xf7\x02\x01w\xc1\x03\x01!^\x04\x01FP\x05\x03\x00H\x00H I\x06\x05\x00\x00\x00\x02\x00\x00\x00\x00\x00\x00\x07\x01\x00\x85\x08\x01\x14\xba\t\x01\'\x10\n\x01\x00\x00\x0b\x01\x00\x00\x82\xc0\x0c\x01\x00\x007\xae\r\x01\x00@\x00\x00\x0e\x01\x00@\x00\x00\x0f\x01\x00\x1a\'\xe5\x10\x01\x00\tW\xad\x0e\r")
2022-05-02 20:08:48.532318500 WARNING:SerialBattery:Modbus Address: 124
2022-05-02 20:08:48.532426500 WARNING:SerialBattery:Modbus Type   : 1
2022-05-02 20:08:48.532430500 WARNING:SerialBattery:Modbus Command: 1
2022-05-02 20:08:48.532433500 WARNING:SerialBattery:Modbus PackLen: 118
I've put more detail in the next post below
For the larger packet I can identify that
AlarmCode seems to be at position 57 - 67 (10 bytes) as that matches AlarmCode: 00 00 10 10 00 00 00 00 00 01
Cycles possibly at 70, 71 as I see 00 85 in there, and I'd think that would be a 2 byte number, and that matches 133
Will need to watch the values tomorrow see if I can identify some other variables. Late and I'm tired 😑
[7c 01 01] [76] [01 10 8d 1c 0d 17 ed 1c 0d 32 8d 33 [modbus addr/reg/command] [length]
0d 36 cd c5 0d b9 8d 20 0d 0c 8d 20 0d 20 0d 01
0d 1c 0d 16 0d 1d 02 01 75 30 03 01 27 10 04 01
46 50 05 03 00 48 00 48 20 4b 06 05 00 00 10 10 [alarm]
00 00 00 00 00 01
07 01 00 85 08 01 15 1e 09 01 [cycles?]
27 10 0a 01 00 01 0b 01 00 00 82 c0 0c 01 00 00
37 ae 0d 01 00 40 00 00 de 01 00 40 00 00 0f 01
00 1a 27 ac 10 01 00 09 57 ad 28 0d [lf]
Comparison time
Have some different data this morning.
Today:
[7c 01 01] [76] [01 10]  [0c c5 0c c7 0c c7 0c c8 0c c5 [Battery#  cell count?]
0c c7 0c c8 0c c8 0c c6 0c c6 0c cb 0c ce 0c c7    [Per Cell Data ? in 2 byte pairs]
0c c8 0c cb 0c cd
 ] 02 01 77 84 03 01 15 87 04 01
46 50 05 03 00 46 00 46 20 48 06 05 [00 00 00 02 Alarm
00 00 00 00 00 00 ]
07 01 00 85 08 01 14 73 09 01 [cycles?]
27 10 0a 01 00 00 0b 01 00 00 82 c0 0c 01 00 00
37 AE 0d 01 00 40 00 00 0e 01 00 40 00 00 01 01
00 1A 27 e5 10 01 00 09 57 ad 12 [0d]
Yesterday:
[7c 01 01] [76] [01 10 8d 1c 0d 17 8d 1c 0d 32 8d 33 [modbus addr/reg/command] [length]
00 00 00 00 00 01
Let's look at the byte data.
[0c c5] 0c c7 0c c7 0c c8   0c C5 = 3269.  This does match our 32.69 nice!
0c c5 0c c7 0c c8 0c c8
0c c7 0c c8 0c cb [0c cd] 3277 Looks correct.
Compare yesterdays first cell reading - 8d 1c  = 36124. hmm not quite, so possibly some bits not used.  Although 3.6124 is possible.
Will try parse out todays data using what I can see and see what the values look like through the day.  Will implement shortly.
After a bit of fighting with endianness got some Cell data out from my inverter.
Values are looking correct(ish). I just need to add a trailing zero (if missing) then divide by 1000 for voltage.
Also tidied up the serial logging a bit so I can see hex data and packet size etc
Example from the cell logging.
Example from packet logging
Now that I can see data I can see some cells are looking a little unhappy - Cell 7 looks low.  Going to plug in directly with the software in a bit see if it's valid or not.
Nice, after a bit of crap code I haz some values.
[Note - Battery, SoC, Consumed are not populated correctly yet]
Top Section / Bottom Section are pulled correctly from data sources.
Cell Voltages are correct (I assume, as I still need to check C7).
Will post my updated driver code shortly.
Current version attached (v 0.1.2 / May 3 2022)
Allows reading of Per Cell Voltage, Hardware Name, Hardware Revision from BMS
Note: Battery Voltage/ Amps/ SoC are not implemented yet.
revov.py
This is also very verbose in the logs, as its a work in progress.
Time for some more data analysis..
Since the voltage is 2 bytes, in big endian order, its likely other data will be also.
So far I've identified a few area's in the data that map to data.  Lets see if we can find more!
Revisiting a data packet  from the same time period, lets see if any values are close.  (TBC...)
0c c8 0c cb 0c cd
00 00 00 00 00 00 ]
As I was about to do some more investigating, my inverter tripped with a  battery ripple warning.  Which its been doing occasionally.
(Hence my trying to get some logs so I can troubleshoot it!)
Plugged in my cable in the interim, and looked at the value for Cell 7 - value looks ok in their software, although with a stateful parameter in red.
I suspect that they might use one of the bits in the first byte to note the Voltage is over, as the value looks valid in the BMS side, but not in my raw data.
BMS is showing 3.625 (with a red Voltage warning).
Raw value is showing
Cell [7] 2.0018 [0x4E32 | 20018] Will add some bitwise logging next to show what bits are set, and see if that is the case.
Also took some more stats from the inverter so i can compare more values
Data from close to that time
Modbus Packet : [7C:01:01:76:01:10:0D:28:8D:20:0D:29:8D:37:0D:45:8D:3A:4E:0B:8D:CC:0D:2C:8D:10:0D:2B:0D:28:8D:16:0D:2A:8D:1D:0D:27:02:01:75:30:03:01:27:10:04:01:46:50:05:03:00:49:00:49:20:4B:06:05:00:00:10:10:00:00:00:00:00:01:07:01:00:85:08:01:15:34:09:01:27:10:0A:01:00:01:0B:01:00:00:83:00:0C:01:00:00:37:AE:0D:01:00:40:00:00:0E:01:00:40:00:00:0F:01:00:1A:3A:04:10:01:00:09:57:AD:2E:0D] (118 Bytes)+6 bytes head/foot =  [7c:01:01:76] + [data] + 2 bytes [2E 0D] Checksum / LF
[HEADER] 7C:01:01:76 Modbus bits  (Cut when passed)
[0..1] 01:10   BatteryModule? | Cell Count
[2..33] [0D:28:8D:20:0D:29:8D:37:0D:45:8D:3A:4E:0B:8D:CC:0D:2C:8D:10:0D:2B:0D:28:8D:16:0D:2A:8D:1D:0D:27 [ Per Cell Data ]
[34..55] 02:01 75:30 03:01 27:10 04:01 [46:50] 05:03 00:49 00:49 20:4B 06:05  11 doubles [18000 = Full Bat Cap?]
[56..65] [00:00:10:10:00:00:00:00:00:01] Alarm
[66..81] 07:01 [00:85] 08:01 [15:34] 09:01 [27:10] 0A:01 00:01  [133=Cycles?]  [5428 = 54.28 V_SUM?] [10000 = 100.00]
[82..97] 0B:01 00:00 83:00 [0C:01] 00:00 37:AE [0D:01] 00:40 [3073 = 3.073] [3329= 3.329? V_AVG/MIN etc?]
[98..113] 00:00 0E:01 00:40 00:00 0F:01 00:1A 3A:04 10:01
[114..117] [00:09 57:AD]
[118..119] [2E] 0D Checksum? ,  LF
Some more guesswork above.  Will implement as noted, then see if the inferred values are guessed wrong or not.
Another modbus packet to compare
[7C:01:01:76:01:10:8D:20:0D:17:8D:21:0D:2F:8D:3B:0D:32:CD:E3:0D:B3:8D:23:0D:0D:8D:24:0D:24:0D:11:8D:21:0D:18:8D:21:02:01:75:30:03:01:27:10:04:01:46:50:05:03:00:49:00:48:20:4B:06:05:00:00:10:10:00:00:00:00:00:01:07:01:00:85:08:01:15:24:09:01:27:10:0A:01:00:01:0B:01:00:00:83:00:0C:01:00:00:37:AE:0D:01:00:40:00:00:0E:01:00:40:00:00:0F:01:00:1A:3A:04:10:01:00:09:57:AD:BA:0D]
02:01 75:30 03:01 27:10 04:01 46:50 05:03 00:49 00:48 20:4B 06:05
07:01 [00:85] 08:01 [15:24] 09:01 27:10 0A:01 00:01 [Cycles] 54.48 Bat Voltage?] [soc state?]
0B:01 00:00 83:00 0C:01 00:00 37:AE 0D:01 00:40 [these haven't changed, so probably not V_min/avg]
00:09 57:AD
I think cycles and Battery voltage look correct.  Will need to check in morning or later if soc state is correct as batteries should be full until after sunset.
New version 0.1.3
Cell Voltage Implemented
Hardware Name Implemented
Hardware Revision Implemented
Battery Voltage added (but not correct!)
Added additional binary logging so I can try spot what bits are used for RED cell errors (not the Alarm error, which I'll get to later)
Added return false for the read_cell_data in case of bad packet.
To do:
SOC, Error Codes, Other variables
Example Logging
revov.py
I think this is good enough as a beta to ask Louisvdw to pull to github.
I'd like testers if anyone else has a revov, so I can check whats different between units/revisions
You'll need an RS485 cable, and a PI (or CCGX)
Also available at https://github.com/csloz/dbus-serialbattery/tree/revov
I have asked for a merge to the main repo.
Further code updates will be published at the repo.
Enjoy!
I just spotted something blindingly obvious.
So obvious in fact that I missed it! 😂
I've re-ordered the data.  See if you can spot it -
7C:01:01:76
01:10 0D:35:8D:2E:0D:36:8D:43:0D:4A:8D:45:4D:D9:8D:D0:0D:37:8D:13:0D:36:0D:2A:8D:20:0D:35:8D:20:0D:2A:
02:01 75:30
03:01 27:10
04:01 46:50
05:03 00:49 00:49 20:4A
06:05 00:00 10:10 00:00 00:00 00:01 Alarm
07:01 00:85
08:01 15:3C
09:01 27:10
0A:01 00:01
0B:01 00:00 83:66
0C:01 00:00 37:AE
0D:01 00:40 00:00
0E:01 00:40 00:00
0F:01 00:1A 4A:3F
10:01 00:09 57:AD
DE:0D
Thats right - the packet structure is actually quite nicely laid out.
We have the header bits and footer bits (in bold).
Then each message has a ID byte, and a Length (although some values are longs, some not)
eg
01:10  with length 16 (10 in HEX) is our battery cell info
02:01 75:30  = 3000  -> 30
03:01 27:10  = 10000 ->100
04:01 46:50  = 18000 ->180
05:03 00:49 00:49 20:4A  = 3 pairs?  73/73/8266 ??
06:05 00:00 10:10 00:00 00:00 00:01 Alarm bits
07:01 00:85 = 133 -> Cycles
08:01 15:3C = 5436 -> Volts (54.36)
09:01 27:10  = 10000 -> 100
0A:01 00:01  = 1
0B:01 00:00 83:66  = 0, 33670 (3.367?)
0C:01 00:00 37:AE  = 0, 14254 (0.14254?)
0D:01 00:40 00:00  = 64, 0
0E:01 00:40 00:00  = 64, 0
0F:01 00:1A 4A:3F  = 26, 190007 (19.000)
10:01 00:09 57:AD  = 9, 22445 (22.445?)
A lot less info to work out. I  think I should be able to map the rest later!
(Bit busy today, so can't touch right now).
