December 17, 20196 yr Hi Everyone, I have some great stock clearance items. Let me start: 1) I have 2 x Brand New unopened PSHY 1200W 110V Wind Turbines. A company were going to build a GTI for them but that did not see the light. Personally I do not have use for the 1200W 110V kit and I will be happy to pass them on for R7500 each. Please note they do not come with any controllers. Controllers for 48V batterys are available on request. 2) I have a Primus Air 30 12V Wind Turbine that has been on a pole for 5 months but it has been on constant brake mode. Thus it has just been parked on the pole. Happy to part with it for R6500 As per picture. It's USA made with a 5 year warranty. Excellent machine perfect for WiFi highsites , CCTV and more. 3) A HAIDI 12.8V 100Ah Lithium Battery in a metal enclosure (Pole Mount). It has not been used. R5000. (Also find its technical sheet) Please find all the Images and technical sheets of all the above items. (Images and PDFs) All items slightly negotiable. Thanks all. Sincerely Jason 2_12V100Ah Battery Pack Specification.pdf Pegasus HY Range.pdf Air_Spec_Sheet_7-2013.pdf
December 17, 20196 yr Author Ps: Just remember the PDFs below all the images on the above post. Thanks all. Sincerely Jason
December 17, 20196 yr 2 hours ago, Energy said: 1) I have 2 x Brand New unopened PSHY 1200W 110V Wind Turbines Ill take 1, maybe the second one as well.
December 17, 20196 yr Author Fantastic Jaco PS: The Primus Air30 has a built in microprocessor in the body. It's a USA built machine. 5 year warranty. Excellent Excellent machine for WIFI highsites and so. Sincerely Jason
December 17, 20196 yr Author Regards the 1200W 110V Turbines. A 48V charge controller is available on order. Sincerely Jason
December 18, 20196 yr 14 hours ago, Jaco de Jongh said: Ill take 1, maybe the second one as well. Jaco, if you don't take the second one as well, I am interested. Do you think this will go nicely with my proposed Victron set-up?
December 18, 20196 yr Author Hi All. The Lithium Battery In the Outdoor Box. Priced reduced to R3500 Sincerely Jay
December 18, 20196 yr Author Dear All. The cost of the 1200W Turbine I have reduce to R5500 no vat applicable . There are two available. 48V battery Controllers are available for these Turbines on request. Everything must go 😆 it's that time of year when the forum softwares and firewall services need to be paid for. So why not grab a turbine for the best price it should be illegal. Hahah. Thanks everyone. Sincerely Jason
December 19, 20196 yr Hi, Can you give us a ballpark figure for the controller? Plus, the big question, like @jasonvanwyk asked, how well will it integrate with a Victron setup? Best regards, Herman Ps, if the first two gentlemen is not taking it, I will be interested as well.
December 19, 20196 yr Author Hi there. Hope well. Because the turbine voltage is high. (110V) the 48V controllers for lead batterys are available for $400 or so. Sincerely Jason
December 19, 20196 yr 20 hours ago, jasonvanwyk said: Jaco, if you don't take the second one as well, I am interested. Thanks for the offer Jason, But I won't take you up on it. Please take my name off the list:)
December 19, 20196 yr 5 hours ago, Energy said: Hi there. Hope well. Because the turbine voltage is high. (110V) the 48V controllers for lead batterys are available for $400 or so. I assume that's 110VDC? If so, you can presumably just use a normal Victron MPPT charge controller and feed that 110VDC as PV power.
December 19, 20196 yr Author 27 minutes ago, PJJ said: I assume that's 110VDC? If so, you can presumably just use a normal Victron MPPT charge controller and feed that 110VDC as PV power. Hi there, All wind Turbines Require controllers to keep them within their safe limits. A 48V battery controller is available for this Turbine. The Controller will take the 110V from the Turbine and make it 48V battery charging ready. Thus it will be : 110V Wind Turbine---> Controller ---> 48V Battery Charging. Sincerely Jason
December 19, 20196 yr Author R14k per 1200W turbine. Turbine and controller. No vat applicable. Supports 48V lead based batterys. Sincerely Jason
December 21, 20196 yr On 2019/12/18 at 8:35 PM, Energy said: Hi All. The Lithium Battery In the Outdoor Box. Priced reduced to R3500 Sincerely Jay Hi Jay Where are you based ?
December 21, 20196 yr Author Hope well. Paarl just outside Capetown We can however ship anywhere you require. Sincerely Jason
January 24, 20206 yr Author 32 minutes ago, MarkK said: Are the turbines still available? Hi @MarkK yes they are.
March 3, 20206 yr On 2019/12/18 at 8:35 PM, Energy said: Hi All. The Lithium Battery In the Outdoor Box. Priced reduced to R3500 Sincerely Jay Hi Jay Can you get me a price on the shipping to Jhb ?
March 10, 20206 yr Author On 2020/03/03 at 8:06 AM, Wildebees said: hi Jason, Turbines still available? - 0792747978 Yes Sir they are. Jay
March 20, 20206 yr On 2020/03/18 at 4:56 PM, Mark Y-M said: Hi Jay, Did you sell that battery? Regards, Mark. Hi Mark I bought it, it is on its way up to Jhb.
