Posted January 29, 20205 yr I'm finally getting around to installing my LFP's (almost a year late!) Finally got a nice 42u rack, and can move out the dead acid, yay! Onto my question - I need to put some bus bars up for + and - to/from inverter and batteries and put a fuse disconnect in. Any suggestions on what to use for bus bars, and where to buy in/around CPT? For fuse disconnects - I was looking at the KETO's - do I need one or two? eg https://thepowerstore.co.za/products/keto-battery-disconnector-with-160a-fuses Thanks!
January 29, 20205 yr 53 minutes ago, shanghailoz said: Any suggestions on what to use for bus bars, and where to buy in/around CPT? I used two earth bars, bought at an electrical supplier (Cronlec in my case). Mounted them in a UT-7s case. Only issue is that the bolt goes through the bar and you need to tighten it from both ends. At the cost its not too bad a source of thick copper bar.
January 29, 20205 yr You Can get copper plate and bars and off cuts from this guys https://www.copalcor.co.za/ They are in Stikland. I had some left overs when waterjet some copper shim rings for my vw aircooled turbo motor that i used for my Lifepo4's. They got of cuts at at back and they work at KG/R.
January 29, 20205 yr AC-DC Dynamics (Paarden Eiland) also sell the threaded copper bars in various sizes - e.g. https://www.acdc.co.za/pages/product-individual?BFC3010 See Rubicon for DC Fuses and Holders - https://www.rubiconsa.com/files/2019/04/Pv-fuses-and-holder.pdf Edited January 29, 20205 yr by NigelL
January 29, 20205 yr See my bus-bar solution, with BMV shunt and Fuses. Uses a Gewiss box (GW44208) and a base-plate split into two sections.
January 29, 20205 yr @NigelL at what place did you buy the black glands and black sleeving? They look really good.
January 30, 20205 yr 16 hours ago, Gerlach said: @NigelL at what place did you buy the black glands and black sleeving? They look really good. Hi Gerlach, I bought some of the glands and the sleeving from Rubicon, but they are quite expensive. AC-DC sometimes have stock of the 25mm and 20mm glands.
January 30, 20205 yr You could also try a new or scrap metal merchant for copper or brass bar. Its very soft to drill and put bolts through to make up your own.
