February 15, 20206 yr Victron MultiPlus II 48/3000/35-32 Inverter March 2019 there was no 5000VA stock so i brought/used this till now ,is less than 1 year old & in as new condition. Only used as UPS R15,000 Private sale so no VAT. Durban Specs are here : https://www.victronenergy.com/upload/documents/Datasheet-MultiPlus-II-inverter-charger-EN.pdf Edited February 15, 20206 yr by 2una
July 16, 20205 yr 26 minutes ago, Shockin said: Can you program it without a gx unit? All victron setups need some sort off gx device,newer ones come with builtin gx
July 16, 20205 yr Author 23 minutes ago, Shockin said: Hi what batteries di you use with this? Can you program it without a gx unit? Hi,using 3 x Pylontech's. Can program the inverter directly without GX but i think the battery bms needs to have the GX present to route thru. I use a venus with mine. That also gives you all your monitoring pages to see via Victron VRM so its worth its cost
July 16, 20205 yr 1 hour ago, Shockin said: Can you program it without a gx unit? If you don't have a GX device you can use a MK3-USB device to a PC. The software called VictronConnect, is a freed download https://www.victronenergy.com/support-and-downloads/software The MK3 cost ~R1000 You could always borrow one, or ask your supplier to help you. Edited July 16, 20205 yr by Louisvdw
