August 24, 201610 yr Author 2 hours ago, SilverNodashi said: Mike, have you bothered using the Infinisolar inverters again? Nope, there has been a few more failures here by the coast or within a 5km radius. corrosion on components from moisture drawn in by the fans if installed in a garage....... as they are IP20 casings. so have decided to use the replus and goodwe as ip65 units and if i must an Imeon in a cabinet so it runs hotter to avoid moisture
August 25, 201610 yr 10 hours ago, Mike said: Nope, there has been a few more failures here by the coast or within a 5km radius. corrosion on components from moisture drawn in by the fans if installed in a garage....... as they are IP20 casings. so have decided to use the replus and goodwe as ip65 units and if i must an Imeon in a cabinet so it runs hotter to avoid moisture don't you do any inland installations?
August 25, 201610 yr Author yep i do, but wont use any of them any more, rather stick with proven products, i don't want a call in a year time even...
October 3, 20169 yr On 25/8/2016 at 4:43 AM, Mike said: .. have decided to use the replus and goodwe as ip65 units and if i must an Imeon in a cabinet so it runs hotter to avoid moisture Just to make sure, I think you mentioned it earlier or somewhere else, those are not stack-able (parallel output on a single phase), right? Thx The websites of those manufacturers are hard to navigate - easier to ask someone who does know them.
October 3, 20169 yr Author not the Goodwe or Replus, there i split the main DB to however many inverters on their own circuits.
October 27, 20169 yr Mike, so you use Replus but not Infinisolar? the 3kw Replus has identical specs to the infini 3kw plus and the replus is 2k cheaper in the power store. Would be interested in your input?
October 27, 20169 yr Author Haggers, No i use the Goodwe 5048ES hybrid - it's a 5kw IP65 based unit, no fans nothing fancy like a screen, just a box with flashing lights and wireless, thats what i use and to know whats happening internaly i use an android phone wheni am out and when at home i have 2 x R450 7inch tablets - one in the office other in the bedroom and i can see all. I would not consider personally using any inverter now that is not IP65 rated unless away from the seaside
