Sheyn Posted August 31, 2020 Posted August 31, 2020 Hi there Recently I have noticed something happening on my two Pylontech batteries (3000 model), when on solar and running on generator. The SOC lights (6 green on) suddenly all turned off with both batteries and after a number of seconds back on. Something similar happened also with one of the batteries. Is this normal? Thanks Quote
Plaashaas Posted August 31, 2020 Posted August 31, 2020 42 minutes ago, Sheyn said: Is this normal? Yes, dont worry. The batteries are just full. Youda and wolfandy 2 Quote
Sheyn Posted August 31, 2020 Author Posted August 31, 2020 Thanks very much for you input. I was just worried, as unfortunately I have a MUST 5kva inverter and although this is a new model and has settings for a lithium ion battery, it doesn't have the option to work along with BMS. Quote
CaTcH21 Posted August 31, 2020 Posted August 31, 2020 Where did you buy your MUST inverter from ? Quote
Rclegg Posted August 31, 2020 Posted August 31, 2020 Yeah that just means the batteries are full. If you read the manual for them it will give you all the various states and their meaning. Quote
Sheyn Posted September 1, 2020 Author Posted September 1, 2020 Thanks to you all for responding so promptly. Your feedback is really appreciated Quote
Sheyn Posted September 11, 2020 Author Posted September 11, 2020 On 2020/08/31 at 8:12 PM, CaTcH21 said: Where did you buy your MUST inverter from ? I purchased it from a local distributor Quote
RedSky Posted September 16, 2020 Posted September 16, 2020 On 2020/09/01 at 12:19 AM, Sheyn said: Hi there Recently I have noticed something happening on my two Pylontech batteries (3000 model), when on solar and running on generator. The SOC lights (6 green on) suddenly all turned off with both batteries and after a number of seconds back on. Something similar happened also with one of the batteries. Is this normal? Thanks Yes, as others have noted this is normal, I run 4 x US2000 Plus batteries. If you run the BatterView software with a console cable connected it will show the battery changing modes when the leds go out, i.e between charging, discharging and idle. Sometimes it might turn 2 batteries in the set to idle at night when there is low load and the lights will go out on those units, just normal part of the BMS operation by the looks of it. Quote
Sheyn Posted September 16, 2020 Author Posted September 16, 2020 21 minutes ago, RedSky said: Yes, as others have noted this is normal, I run 4 x US2000 Plus batteries. If you run the BatterView software with a console cable connected it will show the battery changing modes when the leds go out, i.e between charging, discharging and idle. Sometimes it might turn 2 batteries in the set to idle at night when there is low load and the lights will go out on those units, just normal part of the BMS operation by the looks of it. Great thanks for the helpful feedback Quote
Rachel Posted December 31, 2020 Posted December 31, 2020 Hi. All new to me. Just had my UP2500 battery installed and trying to understand the manual.. has 1 green light on and now i have 3 flashing lights.... please can someone explain in laymans terms if this is correct.. thanks Quote
Miguel Solar Posted January 28, 2021 Posted January 28, 2021 El 31/8/2020 a las 15:15, Rclegg dijo: Sí, eso solo significa que las baterías están llenas. Si lees el manual para ellos, te dará todos los estados y su significado. Hola, que manual es el que hablas?, me podrías dar un link. Gracias saludos desde chile. Quote
iiznh Posted February 3, 2021 Posted February 3, 2021 On 2021/01/29 at 1:43 AM, Miguel Solar said: Hola, que manual es el que hablas?, me podrías dar un link. Gracias saludos desde chile. Hola Miguel, por favor disculpe el español es mi cuarto idioma https://autosolar.es/pdf/US3000-Product-Manual-18BQSV0801.pdf Quote
Happyfounder Posted May 25, 2023 Posted May 25, 2023 Hope you can help. I have just added two Pylontech 3000C to an existing 3 off same. I fully charged the original 3 and then each of the new ones before connecting. They show up on the shine app but whilst they discharge when required they won't accept charge , instead sending any excess to the gris. The lights go out indicating they are full but the app shows 95%....any ideas pls Quote
Happyfounder Posted May 26, 2023 Posted May 26, 2023 17 hours ago, Happyfounder said: Hope you can help. I have just added two Pylontech 3000C to an existing 3 off same. I fully charged the original 3 and then each of the new ones before connecting. They show up on the shine app but whilst they discharge when required they won't accept charge , instead sending any excess to the gris. The lights go out indicating they are full but the app shows 95%....any ideas pls Update.....it obviously needed to sleep on it as this morning I awoke to find the batteries had discharged by 30% overnight and were now recharging as expected..... Quote
