flamegrilled Posted September 3, 2020 Posted September 3, 2020 I have been contemplating disconnecting the Solis Grid tie Inverter and rewiring the Solar panels to divert power to the 2 x Axperts. I have them running as a UPS. Load Shedding is the reason as Grid Tie in SA atm IMO means nothing especially at Stage 4 and during the day when the is sun to be consumed and your GTI is shutdown as a result of a "No Grid" scenario. Am I doing the right thing ? I don't see things (additional power sources) solutions appearing on the horizon any time soon in SA. Quote
Louisvdw Posted September 3, 2020 Posted September 3, 2020 My opinion is that it is not worth while to change it. Grid Tie is quite efficient and it's already installed and working. It does feel like a waste that you cannot charge while load shedding is happening, but if you do look at the actual numbers it would be not that much. flamegrilled and Boerseun 2 Quote
___ Posted September 3, 2020 Posted September 3, 2020 13 minutes ago, Louisvdw said: cannot charge while load shedding is happening If it was me, I'd probably make me some kind of switching solution. So DC breakers are insanely expensive, but... something I saw in a solar R & D workshop, they actually use a plug and socket method so that PV strings (a few on the roof) can be combined to get different voltages and or different power levels. Occasionally someone forgets to turn off the MPPT before pulling a plug and they pull a nice long flame... but other than that, it works quite well for using the same array for multiple purposes. Then... simply switch them PV modules over when you really need to. Or.... get a real inverter and put the Solis on the output. You can even use that nice Hager changeover we all use to only move it there for the duration of load-shedding, or if you really need to move it. Quote
Louisvdw Posted September 3, 2020 Posted September 3, 2020 5 minutes ago, plonkster said: simply switch them PV modules over when you really need to Best of both worlds. I like it Quote
flamegrilled Posted September 3, 2020 Author Posted September 3, 2020 1 hour ago, Vassen said: so maybe consider adding some panels onto the Axperts That looks like the easiest method to approach it. Quote
GreenFields Posted September 3, 2020 Posted September 3, 2020 Microcare offers a PV Auto change over switch on their website for exactly this scenario. Not saying it's the perfect solution for everyone, but it's been done. microcare.co.za/pv-auto-change-switch/ Quote
flamegrilled Posted September 3, 2020 Author Posted September 3, 2020 23 minutes ago, GreenFields said: microcare.co.za/pv-auto-change-switch/ It is perfect if the voltage of the destination inverter can handle the voltage that most Grid Tie inverters can handle about 400-500v. In my case the 4kva inverter is set to a maximum of 145v for PV. Quote
Gerald_D Posted September 7, 2020 Posted September 7, 2020 Since I started putting together systems in 2008 to beat the loadshedding problem, I made the assumption that Eskom would be available more often than sunshine. Charging batteries with Eskom makes more sense to me than using solar. Loadshedding would have to get a heck of a lot worse before Eskom is unreliable for charging batteries. My new house's roof is designed for solar, but I don't think that I would be using it in my lifetime. Quote
Chris Hobson Posted September 18, 2020 Posted September 18, 2020 A DC contactor where the coil is closed via AC would be ideal NO would power off grid NC would power grid tie. ABB make a DC compliant contactor or you could use a ordinary contactor with a snuffing capacitor. Gerrie 1 Quote
Boerseun Posted September 19, 2020 Posted September 19, 2020 On 2020/09/03 at 9:52 AM, Louisvdw said: My opinion is that it is not worth while to change it. Grid Tie is quite efficient and it's already installed and working. It does feel like a waste that you cannot charge while load shedding is happening, but if you do look at the actual numbers it would be not that much. Good advice rather look at adding a Victron inverter with battery bacup into the mix. Quote
