October 10, 20205 yr Good day. I have six 410w panels on a axpert inverter I only get 20 amp output. Hey are connected 2 strings of 3 panels parallel with each other. How can I increase the amps to charge hey are 410w Canadian panels the axpert inverter max input 150v
October 10, 20205 yr These panels output approximately 10A at 40V = 400W. You have 3S2P so you should be getting about 120V/20A. It seems that they are performing as expected. To get more current, put them in 2S3P - that will give 80V/30A. Same power, but good for other reasons. Or, buy more panels....😀
October 10, 20205 yr Author 41 minutes ago, Calvin said: These panels output approximately 10A at 40V = 400W. You have 3S2P so you should be getting about 120V/20A. It seems that they are performing as expected. To get more current, put them in 2S3P - that will give 80V/30A. Same power, but good for other reasons. Or, buy more panels....😀 I have them as 2 string 3 panels and getting 20 amp roughly. I am looking for more amps to charge
October 10, 20205 yr 3 hours ago, StephenB said: I only get 20 amp output This does seem a little low for 6 x 410w panels. I would say you should be at least 28a or maybe closer to 35a counting the losses usually expected. That is assuming your panels are facing north at roughly 30 to 40 degrees.... You sould probably buy some more panels.
October 10, 20205 yr 3 hours ago, StephenB said: I have them as 2 string 3 panels and getting 20 amp roughly. I am looking for more amps to charge if you want more amps, you will have to connect them as 3 strings of 2 panels. Then you will get roughly 30 amps
October 11, 20205 yr 9 hours ago, StephenB said: I have six 410w panels on a axpert inverter I only get 20 amp output. Is that panel amps or battery amps? 9 hours ago, StephenB said: axpert inverter max input 150v Most real (non-clone) Axperts have an absolute never-exceed PV voltage of 145 V (or 450+ V for models with a totally different solar charge controller). PV power starts reducing at 130 V, and when the SCC gets hot. Running the SCC at high PV voltages seems to heat it up a lot. With 410 W panels, almost certainly you will be better off with a 2S configuration (e.g. 2S3P). This will allow you to have higher PV production, resulting in higher charging (battery) current. This is going into my signature now 😐 Edit: or it would if I could figure out how to set one. This forum doesn't seem to support signatures. Sigh. Edited October 11, 20205 yr by Coulomb
October 11, 20205 yr 4 hours ago, Coulomb said: This forum doesn't seem to support signatures. Sigh. You mean like this? Click on drop-down next to your user name at the top of any page. Select "Account Settings" then "Signature". Edited October 11, 20205 yr by Calvin
October 11, 20205 yr 6 hours ago, Coulomb said: This is going into my signature now This is what I said you must do!! 😂😂
October 11, 20205 yr Author 6 hours ago, Coulomb said: Is that panel amps or battery amps? Most real (non-clone) Axperts have an absolute never-exceed PV voltage of 145 V (or 450+ V for models with a totally different solar charge controller). PV power starts reducing at 130 V, and when the SCC gets hot. Running the SCC at high PV voltages seems to heat it up a lot. With 410 W panels, almost certainly you will be better off with a 2S configuration (e.g. 2S3P). This will allow you to have higher PV production, resulting in higher charging (battery) current. This is going into my signature now 😐 Edit: or it would if I could figure out how to set one. This forum doesn't seem to support signatures. Sigh. This is the amps on the LCD coming into the inverter noted will try the 2string option and see how it works out
October 11, 20205 yr 4 hours ago, Calvin said: You mean like this? Thanks! I was expecting the signature to be a profile thing, not an account thing.
October 11, 20205 yr 9 hours ago, Coulomb said: Is that panel amps or battery amps? Most real (non-clone) Axperts have an absolute never-exceed PV voltage of 145 V (or 450+ V for models with a totally different solar charge controller). PV power starts reducing at 130 V, and when the SCC gets hot. Running the SCC at high PV voltages seems to heat it up a lot. What does SCC the abbreviation for?
October 11, 20205 yr Just now, Richard Mackay said: What does SCC the abbreviation for? Solar Charge Controller.
October 11, 20205 yr 14 hours ago, Coulomb said: This is going into my signature now Hey Coulomb, I think you need to be a little more specific in your signature.... Some 410w panels are available in “half cut cells” meaning that they could even be up to 144 cells.. 😂😂😂😂😂😂😂
October 12, 20205 yr 20 hours ago, Solaris said: Hey Coulomb, I think you need to be a little more specific in your signature.... Some 410w panels are available in “half cut cells” meaning that they could even be up to 144 cells.. 😂😂😂😂😂😂😂 Yes, I hope that it's fairly obvious that 144 half-cells = 72 cells. You can't put everything into a signature. I thought of a link to my FAQ page, and still might, assuming that links work there.
October 12, 20205 yr 1 hour ago, Coulomb said: Yes, I hope that it's fairly obvious that 144 half-cells = 72 cells. Yeah I know, I was just messing with you. 😁
