Sunsynk 3.6 inverter
4 hours ago, Tariq said:
just confirmed with Sunsynk technical help desk, the 3.6 does not have a cooling fan
The spec sheets show otherwise. Same general data like the 5kW i.e. cooling fan, noise <30db, 20.5kg weight and 580x330*208mm size.
Hi @Kilowatt PowerYes, I agree, regarding the spec sheet, however, I went back to Ellie’s where I got the inverter, checked out another 3.6, it also did not have a fan, so, hopefully won’t have heating issues
7 hours ago, Energy said:
Slightly lighter but marginal and yes no fan attached. The 3,6kw must be kept in cool garage or room well ventilated. The 3,6kw won't come with fan as it is not high performance in the sense that the 5,5kw can handle more loads meaning the 3,6kw is used for entry level small applications. Sunsynk concludes these low level requirements don't constitute the need for a fan but in my opinion it should still have one.
it is being installed inside the house, so noise was also a consideration, so no fan is great, the main load for 3 hours or so at a stretch will be a 2 kW geyser. Will report back when it is installed, hopefully soon
The 3.6 turns out to have ONE mppt not two as mentioned in all the specifications.
 I could not get the display on mppt 2 to show any readings, I thought the unit was faulty, no one knew this, not even the technical help desk, till they researched it, then only did I find that the 3.6 for South Africa has only one mppt
What is the model number on the sticker on the side?
