Peter Topp Posted March 31, 2021 Share Posted March 31, 2021 Hi Speedster Yes that is correct. You have got it. Quote Link to comment Share on other sites More sharing options...
Paul Greeff Posted April 1, 2021 Share Posted April 1, 2021 16 hours ago, Vassen said: When there is no grid, yes. However, if grid is present, it will also use the battery to feed the non essential loads. To add to Vassens post, the inverter will power non essential loads on grid side, however, You can specify the discharge or power from the battery in System mode. I've set mine to 1.5 kW, so even if someone were to switch on the oven (yes, the oven needs to go) the inverter will only draw 1.5 kW from the battery, and the rest from the grid. Quote Link to comment Share on other sites More sharing options...
Robbo Posted April 1, 2021 Share Posted April 1, 2021 2 hours ago, Paul Greeff said: To add to Vassens post, the inverter will power non essential loads on grid side, however, You can specify the discharge or power from the battery in System mode. I've set mine to 1.5 kW, so even if someone were to switch on the oven (yes, the oven needs to go) the inverter will only draw 1.5 kW from the battery, and the rest from the grid. Just to make sure I understand this option, what would happen if there was loadshedding and someone turned on the oven? Would it just not turn on because it can't draw the required e.g 3kW? Quote Link to comment Share on other sites More sharing options...
Achmat Posted April 1, 2021 Share Posted April 1, 2021 15 minutes ago, Robbo said: Just to make sure I understand this option, what would happen if there was loadshedding and someone turned on the oven? Would it just not turn on because it can't draw the required e.g 3kW? During load shedding, none of of the grid side loads will get any power. Robbo 1 Quote Link to comment Share on other sites More sharing options...
Speedster Posted April 1, 2021 Share Posted April 1, 2021 20 minutes ago, Achmat said: During load shedding, none of of the grid side loads will get any power. Not even from PV? Quote Link to comment Share on other sites More sharing options...
Leshen Posted April 1, 2021 Author Share Posted April 1, 2021 1 hour ago, Speedster said: Not even from PV? Correct. It’s the anti islanding feature of the inverter required by law. Speedster 1 Quote Link to comment Share on other sites More sharing options...
Achmat Posted April 1, 2021 Share Posted April 1, 2021 1 hour ago, Speedster said: Not even from PV? Yes. Not even from pv. The grid connection is closed during grid failure to prevent feed back to the street or shocking anyone working on the line. It's one of the safety requirements. Speedster 1 Quote Link to comment Share on other sites More sharing options...
PeterP Posted May 23, 2021 Share Posted May 23, 2021 On 2021/04/01 at 1:40 PM, Paul Greeff said: To add to Vassens post, the inverter will power non essential loads on grid side, however, You can specify the discharge or power from the battery in System mode. I've set mine to 1.5 kW, so even if someone were to switch on the oven (yes, the oven needs to go) the inverter will only draw 1.5 kW from the battery, and the rest from the grid. If you limit the battery discharge power in System Mode surely this is supposed to limit battery discharge to essential loads only? As I understand it, non-essential loads are not supposed to get power from anything but grid and excess PV, having said that we have one site doing just that (battery power to non-essential loads) and we've been told it will be fixed with a firmware upgrade. I sense there is a lot of confusion around this, and I, for one, am not sure how it is intended to work as we've seen both.... Yellow Measure 1 Quote Link to comment Share on other sites More sharing options...
PeterP Posted May 24, 2021 Share Posted May 24, 2021 From Sunsynk: In time of use set power= essential load, so at night only that much power it will discharge from battery and remaining from Grid , At day time solar will provide both essential and non essential, You need to to Click on zero export only not Zero export to load, Else solar won't provide supply to non essential If solar is less then battery will provide supply to non essential till it will reach SOC, you can control this by Setting % in time of use , suppose you have set 95% then battery will discharge only 100-95% at day time and if you set 20% for night then battery will discharge to 20% in night. So the Sunsynk will supply battery power to non-essentials. Yellow Measure 1 Quote Link to comment Share on other sites More sharing options...
Andry91 Posted December 16, 2021 Share Posted December 16, 2021 Ciao ragazzi sono italiano ero incuriosito di questo inverter, ma qui in italia non se ne parla, vorrei qualche info in piu, chi potreebbe aiutarmi? Quote Link to comment Share on other sites More sharing options...
