May 31, 20215 yr I see this was made available two weeks ago - anyone tried it yet? Or have it already on a newly purchased VMiii? https://www.ostrovni-elektrarny.cz/support/Axpert/FW/
May 31, 20215 yr Intriguing that the 41.xx series are continuing, seemingly in parallel with the 91.xx series. My guess is that the 91.xx series is specialised for one of Voltronics' customers (resellers) with slightly different needs. Edit: in another topic, it was reported that the 90.XX versions are for testing specific problems, and the 45.XX remain the "stable" or "official" versions. Edited June 9, 20215 yr by Coulomb
May 31, 20215 yr Author I know, quite strange. Also, no accompanying change to the MCU firmware. Still 2.61. A changelog really would be great....
June 8, 20215 yr I can say that I successfully flashed this firmware on to my VMIII 24v - and all went well. (flashed via USB) It did prefer a proper restart as ICC didnt communicate properly with some settings but after the inverter restart, that was fine also. I was hoping to flash MCU 02.61 also, but seems you must do that via a COM / RS232 interface, so will acquire that and perform the flash at a later stage.
June 8, 20215 yr Author 2 minutes ago, eHunterADJ said: I can say that I successfully flashed this firmware on to my VMIII 24v - and all went well. Great, thanks for the feedback! Need to get around to doing mine still... I'm already on MCU 2.61 though. I don't suppose you noticed any changes on 41.17?😅
June 8, 20215 yr Nope, not yet. But early days still. I have the annoying 69 error when my Pylon UP2500 starts to float, and I am still seeing that, but am also looking to give it a day or two to see if there's any difference (and it hopefully goes away). - or maybe that gets fixed under MCU 2.61? Will report back if/when I notice any changes.
June 8, 20215 yr Author More likely fixed with MCU as I believe (Could be remembering wrong) that updating the MCU is what gave access to the PYL option in earlier inverters. So I would guess that the MCU controls the comms with the battery.
June 9, 20215 yr Author I see @Coulomb uploaded 2.66 MCU firmware - that's the latest I've seen for the MCU and quite an upgrade from the 2.61 we're currently running! Now I have two things to update on my VMiii!
June 9, 20215 yr On 2021/06/08 at 11:27 PM, JaseZA said: So I would guess that the MCU controls the comms with the battery. Yes, it does.
June 9, 20215 yr 1 hour ago, JaseZA said: I see @Coulomb uploaded 2.66 MCU firmware - that's the latest I've seen for the MCU and quite an upgrade from the 2.61 we're currently running! Now I have two things to update on my VMiii! Interesting... where can a person find @Coulomb's upload?
June 9, 20215 yr Author https://powerforum.co.za/files/file/68-axpert-king-removable-display-firmware-0266rar/
June 9, 20215 yr 3 hours ago, JaseZA said: https://powerforum.co.za/files/file/68-axpert-king-removable-display-firmware-0266rar/ many thanks! will feed back post update.
June 12, 20215 yr So finally, I managed to get the correct USB to RS232 setup and flash the MCU. I decided to go for version 2.66 uploaded by @Coulomb and this is what I have noticed thus far: - I dont have the 69 warning for when the pylontech is float charging anymore, which is great. - A problem I have encountered is that for some reason, I cant manually flip over to battery anymore. It's set to SBU (no power from solar atm), but still it's supplying power from the grid (bypass). If I kill AC power, then it does go to battery just fine, but not when I do the manual switch while AC is supplied. I'll try a few settings but else I might flash 2.61 tomorrow to see how that behaves.
June 12, 20215 yr Decided to charge the pylon from Grid for a while and viola, I am again able to manually switch to Battery! ... Very bizarre. I'll keep an eye for a day or two and see how it behaves.
June 17, 20215 yr Feedback, after almost a week, is that all seems to be working well. The 69 code battery warning is gone and system operating fine. Very happy with results! Thanks
June 18, 20215 yr Author 7 hours ago, eHunterADJ said: Very happy with results! Thanks for the feedback! I still haven't had a chance to update mine...
July 23, 20215 yr Hi. Just a question... Are the 91.20 and 41.17 firmware updates, and the MCU 02.66 suitable for the axpert vm III 48v and/or 24v ??? Thanks in advance for the answers!
July 23, 20215 yr I can only speak for the 41.17 and mcu 2.66... it didnt state if it was for a 24v or 48v, but i installed it on my 24v vmiii and it was fine. the version i had before was the 41.x range so didnt want to try anything from a different range, like 91.x.
March 13, 20224 yr I have downloaded the 41.17 firmware upgrade. Flashed and now it displays ver 20.59... ???? (It looks like the MPP Solar Version. Oops....! Anyone with the same problem. Or where can I find vers 41.14? Have to revert back to the old one... So far not a problem but time will tell. Have load shedding tonight. BTW: New WatchPower1.15SP4 upgrade : https://voltaconsolar.com/monitoring-software/ See topic https://powerforum.co.za/topic/11803-axpert-firmware/ Edited March 13, 20224 yr by DavidB
March 14, 20224 yr 12 hours ago, IcePick1957 said: I have downloaded the 41.17 firmware upgrade. Flashed and now it displays ver 20.59... ???? Did you download it from this forum or from the Czech site in the first post of this topic? I can't explain why it shows that version. It is one of the ones in my collection, so I might have screwed up and uploaded the wrong file, but I've just downloaded it again and checked and it should display 41.17. [ Edit: At least, from software like WatchPower that uses the QVFW command. ] Are you sure you used the right firmware update file? Edited March 14, 20224 yr by Coulomb
March 14, 20224 yr Yep, I used the correct file. Tried yours and the one from the Czech site. Both have the same results. But it's working for now. See my other post.
March 16, 20224 yr @Coulomb I found the correct Version software for 41.17, and it's working 100%. Now it's showing the correct version om my Inverter. I have added it under
March 16, 20224 yr 9 minutes ago, IcePick1957 said: I found the correct Version software for 41.17, and it's working 100%. Now it's showing the correct version om my Inverter. It's so weird. I downloaded your version, and it compares identically with the one I have. I'll put a warning on mine.
March 16, 20224 yr @Coulomb Yep, it is weird. But I think it's best we keep the "versions" separate for future reference and tests. Just for the sake of it, I reloaded yours, still showing 20.59. Reloaded mine, showing 41.17. 🤨 It might be that the Czech guys uploaded the wrong file of the same date. If one hex edit the firmware file one should not notice the difference. But if you compare the 2 PDF files, under the paths in step 5 to 6 you will notice the one displays this version 20.59 in the path. Which tells me he/they used the wrong file. So, hope you are ok with it.
