How I built a HAWT
I would like to share my experience with building my own HAWT. I would also like to chat to other guys who have built wind turbines - either type - to see if any designs could be improved. Maybe I will just post some pics and should anybody have questions, do feel free to reply.
Hi Ww
That's excellent. From now on I'll prefer to refer to you as Sir Ww.
Tell us more about the project:
How many hours did it take you?
What did it cost?
Could you source all the parts locally?
What is the turbine's output? (Watts, and how many volts did you plan for?)
You seem handy and artistic, even with wood. How did you go about shaping the blades?
How do you get a 10m long pole (with a heavy far end) to change a horizontal orientation for a vertical one?
Well done.
Hi Wetkit,
I dont quite follow your question: what do mean by `the unit is sealed'? Only the bearings are sealed. All the coils are embedded in resin and fibreglass, but for the rest, eg the three phases coming out (the alternator is a three phase AC type) and their connections are all open to the elements. Rain water, being pure, cannot short circuit the connections on top of the alternator. Does this answer your query?
windwize
Hi Pony
Shorting the three AC phases with the `kill switch' stops the turbine dead. Braking is achieved by the tail furling up 18 degrees when the wind speed exceeds about 15 to 17 m/s. Thereby turning the blades about 80 degrees out of the wind. The blades keep on producing power at slower speed and do not stop. When the wind speed drops, gravity pulls the tail down which turns the blades into the wind again. Quite ingenious and I think this plan was invented in 1860 or something!
Greetings
windwize
Hi Wetkit
May I reply here to your question about the two solar geysers I put up in series. The photo shows our humble abode with the two silent partners in our fight agains global warming. And may I add, on clear days these  geysers boil at about 13h00. They are up for two years now, but had I known they are so effective, I would have put them up years ago.
Greetings,
windwize
Hi Jakes
You ask many questions at once. Let's take them one at a time:
1. How many hours? Quite some time, but I dont count hours when working for myself. But be sure: it is a lot of work.
2. Cost? I dont have a figure, because again I just know it is inexpensive if you do the work yourself.
3. All the parts are available locally.
4. As with most things in life, you have choices. The watts: output is determined by the magnets (mostly). If you use deonymium magnets for this turbine the magnets alone will cost about R5000 for 24. That is almost 10 times the price of ferrites, BUT they will not give ten times the power output, only 2 to 3 times better. So I opted for ferrites, nice big ones, 75 x 50 x 20. They give me 600 to 800 watts which is fantastic when looking at the price. I believe 24v is better than 12v. Going to 48 uses lots of extra copper which is once again very expensive. So it is 24v.
5. Shaping blades: being a sculptor who have shaped so many wooden sculptures for many years made shaping the blades a pleasure!
6. The tower: not 10, but 12 meters high. Raising the lot (76 mm and 50 mm water pipe) plus the 60 kg alternator and blades is easy. I use a hand winch with a 1: 30 ratio with lots of elbow grease. But the trick here is to use a gin (jin) pole (6m high) over which the steel cable runs. Some people say the gin pole should be a third of the tower hight, but I go for half the tower hight. The higher the easier it is to raise.
Good luck with your own project.
windwize
Eish, what a project!
You mention 24V. Does this mean your output is 24V 3 phase AC. You using some sort of controller with that, or just a simple rectifier?
How does the tail furling work?
Sorry about all the questions, but to date wind power has been to expencive for me, but building it myself might be a project for the next year :)
Hi Wetkit
24v mean my 12v batteries are connected two-two. The alternator produces enough 3-phase AC which goes to 3 bridge rectifiers at the tower. All the DC is then about 40 % higher than the 3 AC supplies.
Can anybody tell me if Microcare and other controllers work the same as the Morningstar I use: The power does not go through the controller as such but is connected directly to the battery terminals. Only when the batteries are full the controller sends the surplus power to a dump load. to prevent the batteries being fried. If a load (fridge, lights etc) is on and power is coming in from turbine or/ and panels, the power takes the shortest route to the inverter, also connected directly to the same terminals. So the electricity does not go through the batteries which extends the battery life.
Furling: Look at the pics, imagine the blades at the front and the alternator upright. notice the tail up when folded/furled. Difficult to explain. Main idea = alternator is mounted off-centre so the wind tends to want to push it around the axis.
WW
  • 1 year later...
  • 3 years later...
