battery terminal corrosion
On 10/27/2016 at 7:20 PM, AndewJ said:
I have noticed that the first battery on the negative side of the inverter corrodes more than the others. Is this normal?
Probably Electrons flow from positive to negative so that battery works the hardest when then bank gets charged.
I have started noticing a bit of corrosion on my terminals, 1.5 year old bank. Is there anything you can do to prevent it? I've heard of vaseline being used, not sure if that is just folklore.
Corrosion is a chemical reaction due to the different "materials" being used together, i.e. a lead terminal with a copper lug. Even if the lugs are tinned the "tin" sometimes comes off on the inside exposing the copper to the lead. And then, sulfation also plays a role as it's "air borne" and the gasses from the batteries close to the terminals play role as well. Vaseline works, or you can buy anti-corrosive paint (normally  blue and red spray paint) or even anti corrosive jelly (which is vaseline with some other chemicals as well)
