Rolo Posted October 18, 2021 Share Posted October 18, 2021 Good day all I have searched but it seems that not many have used the Solis 6kw hybrid inverter. For those who have, may I please pick your brain a bit. I have taken the plunge to install 4x535W panels with the Solis 6kw hybrid inverter in a grid tied configuration (with a conlog bec23 prepaid meter). I also have 2 x 4,8kWh pylontech up5000 batteries connected. Thanks to the guys at conlog I have successfully deactivated the load line reversal trip with the token they gave me. My question is on the running program/mode of the inverter. I am currently running on "self use" mode as I want to charge the batteries with the surplus power not used and then cycle the batteries to 30% during the night. I have found that we will just about make it through the night on the 70% of the battery used. But now, what about load shedding or like in Middelburg the municipality decides it is time for a power cut. Is there some way to program the inverter so that in cycles to 20% when the grid input is lost? During stage 2 loadshedding we sometimes have the time slot of 3AM to 5AM or 5AM to 7AM. That is when the batteries might be at 30% depending on the usage we had during the night. Thats why I would like the extra 10% available if we loose the grid. Thanks in advance Quote Link to comment Share on other sites More sharing options...
Buyeye Posted October 18, 2021 Share Posted October 18, 2021 (edited) @Rolo That is nice inverter I'm looking at upgrading to it or the sunsynk when my municipality allows grid feeding. There should be a setting called low battery cut off, for example I cycle my batteries down to 20% but the cut off is 15%. Edited October 18, 2021 by Buyeye Quote Link to comment Share on other sites More sharing options...
Rolo Posted October 18, 2021 Author Share Posted October 18, 2021 Thanks, I will take a look. It might be that the low cut off is automatic when grid is lost. I see there is a absolute discharge of 10% where the inverter does a battery wake up Quote Link to comment Share on other sites More sharing options...
