June 1, 20224 yr Good day looking for a bit of help here. Sorry if it has been asked before. ive got a kodak 5kw off grid inverter and 1 pylontech up5000 battery. just want to make sure my dip switch is correct. what should dip seitch setting be when using the up5000 with the kodak og5.48. and i will aslo be adding another battery in a month or so what should the changes in the settings be then. ive also noted that with the bms cable connected the batery charges at 53.2v and stays there on float aswell. No problems so far with the bms connection. Just want to make sure all is well these things are so bloody expensive dont want to kill either one of them. Help on both questions will be highly appreciated
June 1, 20224 yr Switch is correct and if you have comms , all ok. HOWEVER , I would suggest to set battery to USE mode and lower the bulk and float voltage to prolong battery life. Also , for me I saw 2-3 times that with the bulk at 53,2 the battery BMS indicated to high charge voltage, so I guess inverter spikes sometime. Since then I've set my inverter to USEr mode , and put bulk voltage at 52,8 and float at 52. Since then no more alarms on pylontech BMS. Edited June 1, 20224 yr by Jaxone
June 1, 20224 yr Author Great thank you very much. if I add another up5000 battery. How do I set the dipswitch and charge amps. Leave them the same? And what setting on dip switch on battery number 2.
June 1, 20224 yr Sorry , on my US3000C the dips are upside down. I have DIP1 ON , 2-3-4 OFF. Battery number 2 leave all OFF. I have 4 batteries in parallel and only master has dip 1 ON for 9600bps the rest are off all. But if you have comms on your inverter I guess they are OK like you have them now
June 2, 20224 yr 7 hours ago, Bronwynn said: How do I set the dipswitch and charge amps. Leave them the same? If you're using battery type PYL and the cable, then there should be no need to change the maximum charge current setting, as the BMS will over-ride it, I believe.
May 21, 20251 yr hellowith regards to dip switch its still confusion this what i have:4 bat pylon UF5000, using can cableBat 1 pin 1 onebat 2 pin 2 onebat 3 pin 2&3bat 4 pin 2kindly advise if this is correctomer
May 21, 20251 yr 1 hour ago, ishtiaq said:hellowith regards to dip switch its still confusion this what i have:4 bat pylon UF5000, using can cableBat 1 pin 1 onebat 2 pin 2 onebat 3 pin 2&3bat 4 pin 2kindly advise if this is correctomerThe binary code goes like this:Bat 1 pin 1Bat 2 pin 2Bat 3 pin 1+2Bat 4 pin 3
May 25, 20251 yr hello im getting different feedback on dip switch including pylontech distributor's site engineer, what do you think ? note the following: bat 1 pin 1 on 2-4 0ffrest of the battires all of the setup aligns some pylontec configuration where the master battery has a distinct setting, and slaves follow a uniform setting thank you your advice in this matter ishtiaq
