Magneto/EMS Heat pump
Hi there,
I'm busy renovating a new pad and have the opportunity to fit a completely new water heating system. I'm keen to install a heat pump, as I've has decent savings from the heating setup at our current house.
Split between fitting a traditional HP setup (i.e Alliance or ITS of +- 5kW output) with 200L of storage OR the 200L integrated unit from EMS, which seems to offer a decent efficiencies, simple installation.
Does anyone have one of these EMS/Magneto units installed? Looking for informed input/opinions.
Thanks!
  • 11 months later...
Hi All,
I am the newly appointed sale rep form magneto thermals - Hendrik Grobler. I have picked up on a lot of questions on various forums regarding the ThermoTank that I would like to address here.
Firstly, everybody is concerned about the performance of the unit, especially winter months - to which I have not found a reply. We have done several field tests on the unit, namely:
The 200L ThermoTank was installed at a resort villa and tested against a 200L conventional geyser with a 3kW in the adjacent villa.
Over the course of 23 June 2023 until 21 July 2023 weekly measurements of the kilowatt readers and water meters were taken. The field test used a total of 20 000L of hot water between the two hot water systems. - which verified that, when compared to a conventional 200l geyser under similar operating conditions, there is a saving of between 55-60% in winter. This scales to upwards of 70% in warmer conditions in summer.
Some additional asked questions that I would like to answer:
1. Can unit be installed outside? - Yes, it can be installed outside. Flex duct can be put on the unit to avoid mass water or to keep leaves out (Keep top side clean).
2. Standing losses: Mid-winter test was completed and tank only lost 4°C, overnight over a 9 to 12hr period.
3. Thermal storage - the preinstalled 2kW backup element is there is the heat pump should fail. However, this is also there to boost the system to 70°C for those that want a little bit extra, or for those with Solar PV system who have extra kW's they like to use.
If anyone has any questions regarding this product, please feel free to make contact with me directly on 062 026 2274 or [email protected] and I will address.
Kind Regards,
Hendrik Grobler
Hi Nick.
We are plumbing contractors in Cape Town that mainly focus on new high-end builds and were looking at alternatives to solar heating or indirect heat pumps because any new build has to have 50% green/alternative water heating and found these Magneto units to be just that.
We have installed roughly 40 units in Cape Town over the last 18 months and have had minimal issues.
Please have a look at the installs we have done on our website. https://www.superplumb.co.za/magento-thermal-tank
I found that installing the units in doors such as a garage especially in coastal environments helps to dehumidify the garage as the heat pumps draws out moisture from the air, however the cold air has to be ducted out doors to avoid the heat pump to cavitate.
Installing it on the roof is fine however inside the roof or ceiling is challenging especially when it comes to servicing and repairs. Servicing usually is only to clean the heat pump head once a year and to make sure the evaporator coil is clean. It shouldn't cost an arm or leg for servicing, air con technicians should be able to service it the same time as when you service the airconditioners in your house.
With only one year warranty if living in the vicinity of the ocean, this unfortunately becomes a far less attractive option that a traditional heat pump unit.
  • 3 months later...
On 2023/11/29 at 1:41 PM, Hendrik Grobler said:
Hi All,
Kind Regards,
Hendrik Grobler
@Hendrik Grobler
Hi Hendrik
In this video Franco Diederiks mentions that this unit is a plug and play unit and that anyone with a bid of experience can install it.
Can you confirm that the home owner with plumbing experience can install this unit and that the warranty will still be valid.
Thanks.
On 2024/01/05 at 6:36 PM, Willem Van Niekerk said:
Hi Nick.
Hi Willem
I see these are low pressure units. What pressure at shower head level are you looking at if installed on ground level for a double story house?
Im considering this instead of a solar geyser and instead using the roof space for additional solar pannels. Opinion on this option?
On 2024/10/13 at 9:14 AM, BarendD said:
Hi Willem
May be refer to the video placed. The hot water used is at the same high pressure as the supply from the authority or feed pump.
The low pressure refers to the heating side from the heat pump.
This is how I see it. I am open to corrections.
Good day PowerForum Members
Hope all is well,
Just a little update from our side as we are proud to announce that we are about at the 2000 sold unit benchmark nationally. Below I will post a video of a well know Economist Dawie Roodt that has installed one of our tanks and his thoughts and feedback on the tank as well.
Should you have any more questions for me or about our Magneto Thermo Tank please feel free to get in-contact with me on 062 026 2274 or on [email protected] . If you would like to become apart of this and become a distributor please also feel free to contact me in changing your business.
Why wait to start saving on your electricity bill if the solution is here now!!
Have a look at our website as well at:
https://ems-holdings.com/
Kind Regards,
Hendrik Grobler
Key Accounts Sales Manager
