October 3, 20223 yr I have seen quite a few people asking about being able to see the SunSynk Flow UI in Home Assistant. So I went playing a bit to see if it is possible to create a custom component in home assistant that would mirror this. Reading a whole lot of documentation on Home Assistant as well as getting to grips with all the possible measurements that is available from the Inverter, I finally have a VERY ALPHA version of it running in Home Assistant and it appears to reflect the UI on my inverter pretty well. Maybe one day I will publish this in HACS and make this custom component available for use. For now there is still a whole lot of learning that needs to happen on building custom components for Home Assistant. Yes I know ... I'm a bit of a #GEEK, but at least now I can see my Inverter's flow screen without going to the garage. 😉
October 3, 20223 yr Going to follow this with intent - is there a github page you are using to track the development etc?
November 6, 20223 yr Grafana 9.2.3 has Canvas Visualizations which can do a similar thing: https://grafana.com/docs/grafana/next/panels-visualizations/visualizations/canvas/
