October 7, 20223 yr Hi guys. Have a friend that has this inverter installed together with some Lead Acid batteries. Inverter is blinking on battery icon and says "0 % Battery" and a "WRN" icon also blinking. Tested batteries just for voltage and they indicate 46.5V .. so I guess inverter shut down battery due to low voltage. I would like to find out what inverter it is and what software can I use to connect to it and see the settings and real time readings.
October 7, 20223 yr 48 minutes ago, Jaxone said: Hi guys. Have a friend that has this inverter installed together with some Lead Acid batteries. Inverter is blinking on battery icon and says "0 % Battery" and a "WRN" icon also blinking. Tested batteries just for voltage and they indicate 46.5V .. so I guess inverter shut down battery due to low voltage. I would like to find out what inverter it is and what software can I use to connect to it and see the settings and real time readings. https://www.cyberpower.com/global/en/product/series/hybrid_pv_inverter This is perhaps a starting point. Edited October 7, 20223 yr by Scorp007
October 7, 20223 yr Author 1 hour ago, Scorp007 said: https://www.cyberpower.com/global/en/product/series/hybrid_pv_inverter This is perhaps a starting point. You think so ? Looking to the models I resembles a bit but none of their models look like the one I saw.
October 8, 20223 yr This one here: https://www.vivaenergi.dk/solcelle-webshop/220v-hybrid-batterilager/hybridpower2031
October 8, 20223 yr This is a Voltronics Infinisolar machine. Rebranded as Hybrid power. You can download Solar Power here: https://www.ostrovni-elektrarny.cz/?podpora It looks similar to watch power but it has some Infinisolar menu options. Edited October 8, 20223 yr by Steve87
October 8, 20223 yr Author 3 hours ago, PowerUser said: This one here: https://www.vivaenergi.dk/solcelle-webshop/220v-hybrid-batterilager/hybridpower2031 Yes, this I know , I am trying to figure out who made it and how to control it. Guy bought the house with it installed and knows nothing about it. The electrician that came to check it knows nothing about it either..
October 8, 20223 yr Author 3 hours ago, Steve87 said: This is a Voltronics Infinisolar machine. Rebranded as Hybrid power. You can download Solar Power here: https://www.ostrovni-elektrarny.cz/?podpora It looks similar to watch power but it has some Infinisolar menu options. Thanks ! Yes, seems to be an Infinisolar E 5.5 ! Thanks again
October 8, 20223 yr 6 hours ago, Jaxone said: Thanks ! Yes, seems to be an Infinisolar E 5.5 ! Thanks again I reckon it's InfiniSolar Plus 3KW / InfiniSolar Plus II 3KW https://voltronicpower.com/en-US/Product/Detail/InfiniSolar-2KW-5KW Edited October 8, 20223 yr by Kilowatt Power Edit: Included an image of the name plate
