January 9, 20233 yr Hi Guys, something similar found on another post here, so not sure if scam or not, so has anyone tried any of these guys or used this battery. Im looking for a bettery setup for my system but nothing to break the bank at the moment Price seems to good to be true, but same on both sites, sites also look like they done well just small spelling on 1 https://lcbsolar.co.za/product-category/lcb-batteries/ or https://energy-outlet.co.za/product/n-energy-48kwh-lithium-ion-battery-rack-mount/?gclid=CjwKCAiA8OmdBhAgEiwAShr409zCYDTMIjp9WAWYWxTjlByAEDar2-uqSbQ3-s89d9NXpxsvvJWB4RoC0-4QAvD_BwE or https://solarboerwarehouse.co.za/product/10kwh-lithium-ion-batteries-back-to-school-sale-40/ also, what mm cable are you using from your batteries to inverter ive got an 5kva Axpert inverter but looking at either going 4 deep cycle or a 5.1kw lithium battery thanks
January 9, 20233 yr Well, I don't know these suppliers specifically so I cannot say whether they are legit or not. However, from experience too good to be true often is... hopefully someone else has had some experience with them and can confirm if they are legitimate or not... As for the battery cable, 25mm welding cable is usually your best bet for battery cable. High current capacity and low resistance, perfect conditions for battery cables and they usually have a decent amount of safety room on the cables limits...
January 9, 20233 yr 1 hour ago, Albert B said: Hi Guys, something similar found on another post here, so not sure if scam or not, so has anyone tried any of these guys or used this battery. Im looking for a bettery setup for my system but nothing to break the bank at the moment Price seems to good to be true, but same on both sites, sites also look like they done well just small spelling on 1 https://lcbsolar.co.za/product-category/lcb-batteries/ or https://energy-outlet.co.za/product/n-energy-48kwh-lithium-ion-battery-rack-mount/?gclid=CjwKCAiA8OmdBhAgEiwAShr409zCYDTMIjp9WAWYWxTjlByAEDar2-uqSbQ3-s89d9NXpxsvvJWB4RoC0-4QAvD_BwE or https://solarboerwarehouse.co.za/product/10kwh-lithium-ion-batteries-back-to-school-sale-40/ also, what mm cable are you using from your batteries to inverter ive got an 5kva Axpert inverter but looking at either going 4 deep cycle or a 5.1kw lithium battery thanks Scam, has all the hallmarks Price, too good to be true Directing you to talk to them on WhatsApp Using a Business Park address, business itself doesn't come up on Google Maps at said address Shipping Policy page has example text - https://lcbsolar.co.za/sample-page-3/ Go look at the prices here on the powerforum store. That's the ballpark you can expect to pay for batteries, sometimes you may get lucky and score something at 10-15% less, but with current demand and loadshedding, you are not going to score a deal, win the lotto or become Eskom CEO
January 9, 20233 yr 51 minutes ago, Albert B said: or https://energy-outlet.co.za/product/n-energy-48kwh-lithium-ion-battery-rack-mount/?gclid=CjwKCAiA8OmdBhAgEiwAShr409zCYDTMIjp9WAWYWxTjlByAEDar2-uqSbQ3-s89d9NXpxsvvJWB4RoC0-4QAvD_BwE I have no opinion about the outlet, but I'd steer clear of that battery. 100ah but you can only charge or discharge at 20A? That's a slow recharge, which you may get away with depending on time between outages, and not a lot of backup power - a bit under 1kW. Which may be why it's cheap. For 4 or 5 grand more you can get a Revov with a little more capacity. For 8 to 10 grand more you can get a Hubble 5.5 kWh (prices obtained with 10 sec of googling). Either will give you a much better charge and discharge rate (4x for the Revoc, 5x for the Hubble), so faster charge and more that you can back up. Also I don't see any CAN connection on that NEnergy product, so comms with some inverters will be a problem. Not all lithium batteries are equal. Not all 5kWh lithium batteries are equal.
January 9, 20233 yr Solar Boer Warehouse 42 Discovery drive, johunnesburg If you get scammed, this is 100% your own fault
January 9, 20233 yr Author 43 minutes ago, Bobster. said: I have no opinion about the outlet, but I'd steer clear of that battery. 100ah but you can only charge or discharge at 20A? That's a slow recharge, which you may get away with depending on time between outages, and not a lot of backup power - a bit under 1kW. Which may be why it's cheap. For 4 or 5 grand more you can get a Revov with a little more capacity. For 8 to 10 grand more you can get a Hubble 5.5 kWh (prices obtained with 10 sec of googling). Either will give you a much better charge and discharge rate (4x for the Revoc, 5x for the Hubble), so faster charge and more that you can back up. Also I don't see any CAN connection on that NEnergy product, so comms with some inverters will be a problem. Not all lithium batteries are equal. Not all 5kWh lithium batteries are equal. Thanks Guys, ill look at those other brands, ive been looking at the Hubble over the last month but saw many people advising their service is very bad and only way some get it to work is to buy a cloud connect for it. Edited January 9, 20233 yr by Albert B
January 9, 20233 yr Author 1 hour ago, Psy said: Well, I don't know these suppliers specifically so I cannot say whether they are legit or not. However, from experience too good to be true often is... hopefully someone else has had some experience with them and can confirm if they are legitimate or not... As for the battery cable, 25mm welding cable is usually your best bet for battery cable. High current capacity and low resistance, perfect conditions for battery cables and they usually have a decent amount of safety room on the cables limits... 4 minutes ago, Albert B said: Thanks, was also looking at the 25mm but the lithium cable looks a lot thinner, so guess ill wait to see what battery im going to get then do the cable
January 9, 20233 yr 8 minutes ago, Albert B said: ive been looking at the Hubble over the last month but saw many people advising their service is very bad and only way some get it to work is to buy a cloud connect for it. Hubble can be a pain, the cloud connect definitely makes it easier. You could get Hubble to work with inverters without it but monitoring the batteries becomes difficult without the cloud connect... You can find a lot of legit suppliers, while the specials aren't as good there are places that aren't too expensive. If you're in JHB drop me a DM and I'll send you a list of some of the suppliers I know and trust for decent prices and services. 2 minutes ago, Albert B said: Thanks, was also looking at the 25mm but the lithium cable looks a lot thinner, so guess ill wait to see what battery im going to get then do the cable Yeah, you could probably get away with a thinner cable in many occasions... I usually advise a minimum of 16mm but 25mm is a safer option and should be ample regardless of the ratings on the battery/inverter.
January 9, 20233 yr Author 46 minutes ago, Bobster. said: I have no opinion about the outlet, but I'd steer clear of that battery. 100ah but you can only charge or discharge at 20A? That's a slow recharge, which you may get away with depending on time between outages, and not a lot of backup power - a bit under 1kW. Which may be why it's cheap. For 4 or 5 grand more you can get a Revov with a little more capacity. For 8 to 10 grand more you can get a Hubble 5.5 kWh (prices obtained with 10 sec of googling). Either will give you a much better charge and discharge rate (4x for the Revoc, 5x for the Hubble), so faster charge and more that you can back up. Also I don't see any CAN connection on that NEnergy product, so comms with some inverters will be a problem. Not all lithium batteries are equal. Not all 5kWh lithium batteries are equal. Hi, any place you can recommend that sells them at a good price also does anyone know how the super cap batteries are and what they go for. how many hours will a 5.1kwh lithium battery give if the draw on it is between 500 to 1000w thanks
January 9, 20233 yr 22 minutes ago, Albert B said: Thanks Guys, ill look at those other brands, ive been looking at the Hubble over the last month but saw many people advising their service is very bad and only way some get it to work is to buy a cloud connect for it. I don't own a Hubble, and I'm not an installer. I hold no brief for that brand. That 20A current limit on that Nenergy battery seems to me to be problematic. The other brands I mentioned (by no means the only alternatives) both offer faster charging and can carry a higher load. So if I made the point that not all 5kWh lithium batteries are equal, and there are good reasons why some cost more (or why some are cheap) then that's the point I wanted to make. Edited January 9, 20233 yr by Bobster. sppelling
January 9, 20233 yr 1 hour ago, Albert B said: also does anyone know how the super cap batteries are and what they go for. I'd suggest you steer clear... very scammy. 1 hour ago, Albert B said: how many hours will a 5.1kwh lithium battery give if the draw on it is between 500 to 1000w About 10-5hrs.
January 25, 20233 yr Perhaps another one. https://www.4x4community.co.za/forum/showthread.php/362316-Scam-Solar-batteries Be very careful all you guys.
February 1, 20233 yr solarboer is definitely a scam. The other 2 have the same specials , same picture as well. I'd say 99% they are a scam as well. All just have random google street view images at their addresses. This is common with the scammers. There seem to be so many scam businesses in the solar game , you have to be very careful or you will be scammed. Ask them if you can come and see the items you are interested in at their "premises" and see what excuses they come up with.
February 2, 20233 yr Does anybody know what is going on at BOVUA SOLAR? I bought a lot from them over the last few months. Made a purchase last week, paid, confirmed. Now suddenly can not get hold of them on any platform.
February 8, 20233 yr Author so im still on a hunt for lithium battery 2 seem ok not to sure which if better or proffered but seen 5.1kwa Revov 2nd life and Pylontech 4.8kwh so guessing the 16 cell vs 15 cell but im leaning to Revov. my brother inlaw can probably get me Huawei think its either 4.8 or 5.1 kwa sor about same price what all do you guys recommend and from where can i get it so i can see prices Its for my 5kva Axpert inverter Thanks
February 8, 20233 yr Does not look good, so if you really want to use them, rather go check whether they really exist: https://www.hellopeter.com/bovua-solar
February 8, 20233 yr On 2023/02/02 at 7:50 AM, Kobus Kruger said: Does anybody know what is going on at BOVUA SOLAR? I bought a lot from them over the last few months. Made a purchase last week, paid, confirmed. Now suddenly can not get hold of them on any platform. I would also be wary. Reason is pricing too good to be true all the time. Thus not on short period specials. Also payment, premises, telephone contact, see the goods etc.
