Item Wanted:
Hi Guys,
Any one know of a supplier ( local ) that supply components other that RS, Communica or Mantech? I am looking for capacitors 80V 3900UF 25x50 snap in. I can get from the USA but would be better if its local..
Thank
On 2023/02/24 at 8:25 AM, Dewald Brink said:
Hi Guys,
Thank
It depends if you want the cap for an inverter, in which case you will have to go for 105 degree C rating, Communica mostly has only standard 85 degree C.
If you looking for 1 or 2 only, let Mantech get it for you if they dont have the item.
Else if your purchase is R2000 or more you get free shipping from Digi-Key.
Thank you for the reply, I have checked with Mantech they can't help me... I was told. The only place I can get from is Digi-key, I need about 30 of them hopefully that will cover the shipping too...
Thank you
On 2023/02/27 at 5:04 PM, Dewald Brink said:
Thanks for the input guys, I ordered from Digi-Key this morning, parts already on the way...
One can count on the states for service...
thanks again
Hi @Dewald Brink I am also on the verge of ordering components from DigiKey. What do I expect to pay for import duties, as DigiKey just state that this is on the buyer? . I am also buying capacitors.
On 2023/03/01 at 7:15 AM, Dewald Brink said:
Not Sure what the duties would be... still waiting for that surprise... it is my understanding that one does not pay duties on components... I could be wrong..
I am expecting delivery on Friday so we will see...
Any update?
25 minutes ago, reapster said:
I ordered R2k of parts (IGBTs, caps, power diodes) from DigiKey. Super quick courier, but got nailed for R628.80 customs/import duties. This was Sept, 2022.
Thank you so much for valuable info. Ouch thats nearly 30 percent of value😢On top of this duty, must you still pay VAT of 15 percent?
Edited by BritishRacingGreen
Extra info
Hi Guys,
Received the my 20 caps yesterday... Digi-Key's service is very good, same as RS and the price is also very similar,  I had to pay + -  R630 for customs clearance. So In total the caps work out to about R150 per item. I don't think its to bad as no one in SA could supply me...
I will use them again for other parts too.
Regards
Thats less than 2 weeks from order to delivery including customs clearance - Very quick
