May 13, 20242 yr Thank you! I purchased the kit of 2 fans, I hope it will be enough https://it.aliexpress.com/item/1005004053911701.html?spm=a2g0o.order_list.order_list_main.5.43e13696NJoDVy&gatewayAdapt=glo2ita
May 14, 20242 yr 18 hours ago, wifi75 said: Hello does the fan you installed above the inverter aspire air? Indeed it does, essentially sucking the warm air out and creates a circulation or cooler air from the bottom.
July 5, 20242 yr Hi peeps, I got four of these fans to cool down my inverter and other items, my challenge now is how do I connect these to a 12v supply? If possible can i use adapters with 4-pin 12V to AC? Or should i cut off the connectors and just use +ve and ground to a power supply? https://www.rebeltech.co.za/noctua-nf-b9-redux-1600-pwm-92mm-pwm-nf-b9-redux-1600p-case-fan.html
July 5, 20242 yr 14 minutes ago, Jakac said: I got four of these fans to cool down my inverter and other items, my challenge now is how do I connect these to a 12v supply? If possible can i use adapters with 4-pin 12V to AC? Or should i cut off the connectors and just use +ve and ground to a power supply? You simply wire them to a 12V DC power supply; red to positive and black to negative. You can use the old style black connector blocks or anything of the more modern connector blocks. And yes, I snipped off the connectors that the fans came with.
August 13, 20241 yr Pimping the ride... Why do something simply when you can over-complicate it? On my 8kW Sunsynk I'm going to use 4x 12V Sunon fans which have 3 wires - red, black and yellow. The yellow wire provides a square wave output proportional to the fan speed. I'm using this to detect if a fan is slowing down or has stopped using a small monostable electronic circuit which lights a green led if fan speed is ok or red led if fan speed is below a minimum. This way a simple visual indication tells you whats up with the fans. Breadboarding on the bench has produced satisfactory results so now I've designed a pcb and am busy ordering components. The board and fan work off 12V which I get from a 48-12volt buck converter (Mean Well model PSD-15C-12) connected to the Li-ion battery via an inline fuse. Putting the fans, power supply and pcbs into 40x100 trunking should work nicely. Next level would be to add a microcontroller and display all fan speeds on a small OLED. Or would that be going to far? Mind you with that in place you could easily add a bluetooth link to a phone app to display fan status... or even link it into the Sunsynk wifi dongle to show fan status as part of the Sunsynk online app. Now that could be useful. PS: here is the schematic for the fanspeed monitor. and a rendition of the pcb Edited August 13, 20241 yr by Mach4 Add image
February 16, 20251 yr On 2023/09/11 at 5:17 PM, slipx said: Hi. I'm running ESPHome with the config below. substitutions: device_name: sunsynk-fan-controller friendly_name: "sunsynk fan-controller" device_description: "Fan with speed control" temperature_threshold_low: "22" # At what temperature, in celcius, should the fan turn on to its minimum speed temperature_threshold_high: "45" # At what temperature, in celcius, should the fan turn on to its maximum speed minimum_fan_speed: "25" # What is the minimum fan speed, as a percentage esphome: name: '${device_name}' comment: '${device_description}' platform: ESP8266 board: d1_mini # Enable logging logger: # Enable Home Assistant API api: encryption: key: "" wifi: ssid: !secret wifi_ssid password: !secret wifi_password # Enable fallback hotspot (captive portal) in case wifi connection fails ap: ssid: '${device_name}' password: !secret fallback_password fast_connect: true power_save_mode: none captive_portal: ota: safe_mode: true reboot_timeout: 10min num_attempts: 5 # PWM output for the fan speed control output: - platform: esp8266_pwm pin: D0 frequency: 22000 Hz id: pwm_output sensor: - platform: homeassistant name: "ACTemp" entity_id: sensor.sunsynk_radiator_temperature id: temperature_sensor on_value: then: - script.execute: set_fan_state # The actual fan entity presented to Home Assistant fan: - platform: speed output: pwm_output name: "${device_description}" id: "the_fan" # on_turn_on: # - switch.turn_on: fan_relay # on_turn_off: # - switch.turn_off: fan_relay script: - id: set_fan_state then: - if: condition: lambda: |- return id(temperature_sensor).state < id(${temperature_threshold_low}); then: - fan.turn_off: the_fan else: - fan.turn_on: id: the_fan speed: !lambda |- if (id(temperature_sensor).state >= id(${temperature_threshold_high})) { // Over upper threshold, fan speed at maximum ESP_LOGD("Fan speed calc", "Temperature is above or equal to upper threshold so setting to max"); return 100; } else { float calc_speed = ((100-id(${minimum_fan_speed})) / (id(${temperature_threshold_high})-id(${temperature_threshold_low})))*(id(temperature_sensor).state-id(${temperature_threshold_low}))+id(${minimum_fan_speed}); ESP_LOGD("Fan speed calc", "calculated speed = %f", calc_speed); return calc_speed; } Can you show how wiring and power the fans (type of fans and voltage) because mines they does not work with pwm. Thanks
