March 23, 20233 yr EDIT : PROBLEM MOSTLYSOLVED. TURNS OUT THE ROUTER WAS CONSTANTLY CHANGING THE IP ADDRESS OF THE RASPBERRY EVERY TIME POWER FAILED. FYI: SA does not control your inverter fully. I've been trying to change output source priority in SA to no avail. Got an email this morning from Pierre at support saying the software is not supposed to change how the inverter behaves, it can only change certain values. Im thinking here he means say battery volts etc. Thought this would be useful to people thinking about buying it. The graphs and data are great though. And for R900 not so bad. Edited March 25, 20233 yr by sunset1 Issue mostly solved
March 23, 20233 yr Fair point, but it is a continuously evolving piece of software that allows you to do quite a bit remotely on your inverter and battery. I have seen quite a few new features added over the past 18 months which has given me more and more control over my entire system. MdF
March 23, 20233 yr Output source priority would change fine for me on kodak systems. Most settings would change fine, some required to be done twice then it would reflect. Solar assistant is worth it's weight in gold
March 23, 20233 yr 54 minutes ago, abd7 said: Solar assistant is worth it's weight in gold I agree. Does everything it needs to do.More than enough data.Thanks Solarassistant.
March 23, 20233 yr 2 hours ago, sunset1 said: FYI: SA does not control your inverter fully. I've been trying to change output source priority in SA to no avail. Got an email this morning from Pierre at support saying the software is not supposed to change how the inverter behaves, it can only change certain values. Im thinking here he means say battery volts etc. Thought this would be useful to people thinking about buying it. The graphs and data are great though. And for R900 not so bad. what did you want to change / control that wasn't provided for?
March 23, 20233 yr Author I want to change output source. Ie from solar to utilty. The option is there in configuration in SA but no changes are made on the inverter.
March 23, 20233 yr Author 8 hours ago, abd7 said: Output source priority would change fine for me on kodak systems. Most settings would change fine, some required to be done twice then it would reflect. Solar assistant is worth it's weight in gold Hi, can you explain what you mean by it needs to be done twice? The same toggle just twice, or do the same thing somewhere else in the configuration?
March 23, 20233 yr Author 7 hours ago, Chris Louw said: I agree. Does everything it needs to do.More than enough data.Thanks Solarassistant. well done! Im so happy for you!
March 23, 20233 yr 9 hours ago, sunset1 said: I've been trying to change output source priority in SA to no avail. i just changed my output from solar to utility as a test (via my phone), and it works as it should
March 23, 20233 yr Some clonexperts are sticky with changes ie they need to be done in an order,that sounds more like an inverter issue SA sends the command,whether the inverter listens to the standard command and does it - that's a different question
March 23, 20233 yr Author 1 hour ago, PsyWulf said: Some clonexperts are sticky with changes ie they need to be done in an order,that sounds more like an inverter issue SA sends the command,whether the inverter listens to the standard command and does it - that's a different question Makes sense since it seems most don't have this issue. For the record, full circle solar VM 1000, ie Voltronic is not configurable as of yet with SA. Despite their documentation saying so.
March 23, 20233 yr Author 1 hour ago, Andre Kruger said: i just changed my output from solar to utility as a test (via my phone), and it works as it should What inverter you have?
March 23, 20233 yr 7 minutes ago, sunset1 said: For the record, full circle solar VM 1000, ie Voltronic is not configurable as of yet with SA. Despite their documentation saying so. I wonder if the Full Circle is a Fake Axpert,or Axpert-like clone rather,some chinese units do a pretty bad job of duplicating the software. Did you test configuring the unit with Watchpower?
March 25, 20233 yr Author On 2023/03/23 at 9:16 PM, PsyWulf said: I wonder if the Full Circle is a Fake Axpert,or Axpert-like clone rather,some chinese units do a pretty bad job of duplicating the software. Did you test configuring the unit with Watchpower? Looks like the problem is fixed. Its strange because everything works great now except that the inverter gets hung up on utility powering the loads even when it's set to solar first with good sun and a full battery. Not sure where the hiccup lies here. I did notice this morning it kicked over to solar after a high load kicked in - sort of woke it up. Or perhaps she needs a good 10-15.min to adjust to the setting. Edited March 25, 20233 yr by sunset1 Grammar
