Grid Frequency Limits
On 2023/05/20 at 8:48 PM, grant.cpt said:
Anyone know what the Upper and Lower limits are of the Grid Frequency?
Baseline: 50Hz
Looking at setting up alerts in what my inverter measures
As spesified by:NRS 048-2:2004
Edition 2.1
Grid ± 2,5% (± 1,25 Hz) lower limit = 48,75hz upper limit = 51,25hz
Edited by TaliaB
15 hours ago, Chris.P.Bacon said:
How accurate are the Axpert inverters at reading the frequency?
I'd also like to set an alert for mine, I've noticed incredible fluctuations the past 60 days.
Good question.
@Coulomb could you perhaps shed some insight?
Can you post a graph of the frequency measured over say a day.
@Scorp007 here is the frequency in my area for the last 12 hours. Lowest at 49.6 H but I've seen it slightly lower.
And for interest sake here is the grid voltage as well.
image.thumb.png.0980f465d0a67804be4f9e5354caa0f1.pngimage.thumb.png.3410d6d58580e0fb81177ad7afb6c533.png
Edited by Antonio de Sa
So all together no problem at all.
Thanks for the pics.
I would think very good. The DSP is of course running off a crystal, and there is capture hardware used, and an interrupt dedicated to zero crossing of the AC input. Frequency measurement is simple with that setup.
