July 2, 20233 yr I have FOUR Giter 2.56kW 50Ah 48V for sale R8500 each perfect working order, i just want to upgrade Edited August 6, 20232 yr by jlr
August 6, 20232 yr Author Can anyone help with what batteries can communicate with the Kodak 7.2? The batteries i wanted to replace the Giters with is out of stock and now need to know which other batteries i can consider?
August 10, 20232 yr On 2023/08/06 at 2:17 PM, jlr said: Can anyone help with what batteries can communicate with the Kodak 7.2? The batteries i wanted to replace the Giters with is out of stock and now need to know which other batteries i can consider? Probably, Pylontech
August 10, 20232 yr On 2023/08/06 at 2:17 PM, jlr said: Can anyone help with what batteries can communicate with the Kodak 7.2? The batteries i wanted to replace the Giters with is out of stock and now need to know which other batteries i can consider? I can confirm that the Greenrich 3.686KWh batteries does communicate with the Kodak Max 7.2Kw inverter with the Pylontech communication cable and Pylontech profile set on the inverter, I am not sure if the 5KWh and 6.1KWh can communicate with the Kodak Max 7.2Kw inverter.
