July 24, 20188 yr TTT I will be your apprentice . Some of the skeletons now climbing out the cupboards . SECRETS
July 24, 20188 yr 3 hours ago, Chris Hobson said: TTT you're still an amateur. Ya recon ... you should have seen the 200w panel's connection box after I re-wired the 2 panels from parallel to series. If I did not have software to check the volts when I got back down, and back up that fast, that panel would not have lasted much longer. EDIT: Panel was piping hot, burnt my hand, the other panel "cool" in the midday sun in comparison. Edited July 24, 20188 yr by Guest
July 24, 20188 yr 7 hours ago, The Terrible Triplett said: Ya recon ... you should have seen the 200w panel's connection box after I re-wired the 2 panels from parallel to series.
July 24, 20188 yr 7 hours ago, The Terrible Triplett said: Ya recon ... you should have seen the 200w panel's connection box after I re-wired the 2 panels from parallel to series. TTT, what was the root cause? There was some bug in the wiring, yes?
July 24, 20188 yr 2 hours ago, Youda said: TTT, what was the root cause? There was some bug in the wiring, yes? Root cause ... haste. The rules I learnt that day:Rule 1: It is not recommended to alter anything on a blistering hot Saturday midday, when you have to SIT on a metal roof, on top of a double storey house.Rule 2: Even less advisable to take a break on said hot day, in a air-conditioned room. (you have to go back up)Rule 3: And it is never ever advisable, to quench ones thirst, with one Castle Light whilst sitting in the air-conditioned room. (false sense of completion) 2 hours ago, seant said: So is the guys pump working or not , cause I think we've scared him off I hope @Buckworth has seen that we are quite a happy bunch here.
July 25, 20188 yr 5 hours ago, The Terrible Triplett said: with one Castle Light Should have had a beer instead...
