December 6, 20232 yr 2 hours ago, Bobster. said: The combination of these two factors means that the total demand and what I use from PV has dropped, but what I draw from the grid has stayed pretty constant, and so grid power consumed as a % of power consumed by the house is rising. This makes me grumpy. Strange, since I installed my system from an average 22 KW/h a day from grid I managed to reduce it to about 5 Kw/h see dashboard of my last 90 days.
December 6, 20232 yr 22 minutes ago, Antonio de Sa said: Strange, since I installed my system from an average 22 KW/h a day from grid I managed to reduce it to about 5 Kw/h see dashboard of my last 90 days. also @Bobster., via the extension lead the monetary grid amount was effectively nil, to me, but we were using 2-3kWh extra per night, that the battery would not have had capacity for... now if we wanted a prepaid meter from Eksdom, which they refused to put in when asked a few years ago, we'd be looking at R 8.00 per unit/kWh, not an option and mark this text, this is what will be the target unit price elsewhere, I suspect, I've got 16 x 304Ah cells coming, hopefully before the weekend (that aught to keep me out of mischief for a day or 2) and once that is added to the existing 8k2W battery, we should be fine overnight, without manually cycling various loads... Certainly we've gone from over 30kWh/day, 5 years ago, to 20-24kWh/day these days, the consumption will go up again, but all of it will be solar sourced and battery supported after dark...
December 6, 20232 yr 1 hour ago, Antonio de Sa said: Lovely graphs. Where are you sourcing the cloud cover and load shedding information?
December 6, 20232 yr 17 minutes ago, p_i said: Lovely graphs. Where are you sourcing the cloud cover and load shedding information? @p_i The load shedding schedule is linked to the ESP app, the cloud cover from our nearest weather station, it's quite accurate.
December 6, 20232 yr Not a productive day in Randburg. On a good day my battery is charged by 10:30. Today it hasn't seen more than 80% SOC.
December 6, 20232 yr 2 hours ago, Kalahari Meerkat said: now if we wanted a prepaid meter from Eksdom, which they refused to put in when asked a few years ago, we'd be looking at R 8.00 per unit/kWh, 😮 that is hell of expensive for electricity. Even good old COJ, not knowing for having the most attractive electricity prices, is charging R2 and some change.
December 6, 20232 yr 4 hours ago, Antonio de Sa said: Strange, since I installed my system from an average 22 KW/h a day from grid I managed to reduce it to about 5 Kw/h see dashboard of my last 90 days. My bad. I meant what I've been drawing from the grid since I first converted to PV. At conversion time I was using 13kWh total and about 1.2 from the grid on a good day (I know... it's wastrels like me that bump load shedding up a stage). These days I'm using 10 to 11 total, but still about 1.2 from the grid. That's because of the inverter - I think it's the way it's designed. But I suppose I could try asking Goodwe support about this. They'll probably tell me to use some time-based rule.
December 6, 20232 yr Author 4 hours ago, Bobster. said: Not a productive day in Randburg. On a good day my battery is charged by 10:30. Today it hasn't seen more than 80% SOC. For me today produced 60% of a full sunshine day so around my daily needs. Good enough for me. Sunday I expect no sun so that would mean grid use for the day for about 80% + of our needs. Depends as usual how busy the kitchen will be 😀 LS today from 16h. Edited December 6, 20232 yr by Scorp007
