Gauteng Who is not using grid....
  • Replies 157
  • Views 18.4k
  • BritishRacingGreen
    BritishRacingGreen
    Ja, en ek charge my betteries vanaffie grit, en die loadsheddink experts kry a fit 😄
  • Antonio de Sa
    Antonio de Sa
    Here is my system performance yesterday, by 10:30 AM battery fully charged, geyser done and dusted, the rest of the day what a waist.
  • Everyone in Jozi is having cold weather 😝 nice 26° in CPT today with fairly good solar production. I flew down to Jhb yesterday and boy was it cold happy to be back in Cpt today. One of my clients in
17 hours ago, Chris Louw said:
@gimme_power  Go on pension and then move washing to a sunshine day.
Haha, yes you are right, but I am 10 years out so will have to stick with a helper for now 🙂  On a normal summer day I have no problem at all.  I am doubling my battery capacity with a diy battery build over the holiday so that will leave max 5% of days where I need any grid at all.  Not days like above though.
Edited by gimme_power
1 hour ago, madness_za said:
Great solar today, running almost close to max of my panels
Gauteng is a big place then.
I'll do OK today. My system hit 98% SOC at 12:00 - just in time for the heat pump to kick in. On a good day it's charged by 10:45. The heat pump set the SOC back about 3% because load > solar. But the system should get time to recharge if it stays sunny.
So OK, but I'm not breaking any records.
Hi @gimme_power what DIY battery you going for, what battery do you currently run, is it also a DIY. I am looking at the Apexium 280Ah diy kit myself.
Gauteng after this heat wave we are in for a good few poor solar production days, even maybe past the 15th Dec.🤔 Post some production graphs from around the country and see which province comes out tops😜
Edited by TaliaB
Added sentence
Yes. It's not looking too rosey. Large numbers of Vaalies at the seaside will ease the traffic and make it easier to get restaurant bookings, but won't help our PV.
Though I seem to recall that December/January is not the best time for PV in Gauteng.
Edited by Bobster.
37 minutes ago, Kalahari Meerkat said:
There can only be one - Noordkaap, hands down...
I agree NC has the highest solar irradiance, but just watch out for the de-rating factor of your 50°plus temps🤣
From Sunday we have had some clouds that helps with the heat but not good for solar production. Yesterday 18:00 is was still 42º
I only look a week ahead as longer range guess work can be way out.
For now I see Sunday and Monday as the worst for the week. Glad that Sunday could be overcast the whole day. Give us a break from the heat. 😀😀😀
Ok, the last couple of days... the extension lead to the neighbour is no more... temperatures up to somewhat high numbers in the shade, but not enough battery capacity and not enough load during the day... 4.7kWp panels doing not much most of the time and it due to lack of load, got the pump running during sunshine... that adds 600W of so to the load, but really, maybe need to mow the lawn daily or something like that 🙂
Northen free state. My last seven days, used a bit of grid power. Max PV 4.75 KW out of 4,7 Kw panels
Edited by Antonio de Sa
10 minutes ago, Bobster. said:
Use the mower as a fan.
and end up looking green by all the grass cuttings being thrown your way 🙂
Need to really look at putting in an inverter aircon or two, into the house, that could consume some energy and maybe prevent this:
Quote
Date: 2023-12-05T13:44:09, Temperature: 31.6°C, Humidity: 39.7%
Date: 2023-12-05T13:45:09, Temperature: 31.6°C, Humidity: 39.8%
Date: 2023-12-05T13:46:10, Temperature: 31.6°C, Humidity: 39.7%
Date: 2023-12-05T13:47:10, Temperature: 31.6°C, Humidity: 39.8%
Date: 2023-12-05T13:48:10, Temperature: 31.7°C, Humidity: 39.8%
Date: 2023-12-05T13:49:11, Temperature: 31.7°C, Humidity: 39.9%
Date: 2023-12-05T13:50:11, Temperature: 31.6°C, Humidity: 39.9%
Date: 2023-12-05T13:51:12, Temperature: 31.7°C, Humidity: 39.9%
Date: 2023-12-05T13:52:12, Temperature: 31.7°C, Humidity: 40.1%
Date: 2023-12-05T13:53:12, Temperature: 31.7°C, Humidity: 40.3%
Date: 2023-12-05T13:54:13, Temperature: 31.7°C, Humidity: 40.3%
Date: 2023-12-05T13:55:13, Temperature: 31.7°C, Humidity: 40.3%
from being the case in this room... probably nearly the coolest room in the house... south and slightly west facing... around 210 degrees, I think...
good stuff, here... can't show the graph, but lets see...
PV1 = 9 X 280Wp = 2520Wp
PV2 = 8 X 280Wp = 2240Wp
so PVpotential = 4760, nearly the same as yours 🙂 anyway, seeing a 4969W peak on the 2nd of Dec at 12:13:59, the 2nd highest peak of 4832W, yesterday at 11:07:38, some cloud edges, I guess, helping, but it wasn't totally cloudy, at least, today, pretty much clear skies all the way... and battery full by 12:19:06, today...
I bought 32 of those SVolt 184Ah cells earlier in the year. So need to get them assembled. I currently have 3 Averge 48100S packs
Seriously, the amount of power that my property uses has gone down since I got solar.
There are two consequences of this
1) The system shuts down at night. I presume this is triggered by total demand dropping below a certain level. So I use grid power every day, and most of it is in the small hours when the house could easily be running off of battery. Which is annoying.
2) The payback calculation gets worse and worse. When I switched to PV we were averaging 13 to 14 kWh a day. Now it's 10 to 11. So how much am I saving on the meter? (This may help me if there's a prolonged power outage, because the battery will last longer).
I started running ALL my external lights at night. But they're all LED and draw next to nothing. So I need to invent or install some load that will keep the system feeling wanted at 2 or 4 in the morning.
The combination of these two factors means that the total demand and what I use from PV has dropped, but what I draw from the grid has stayed pretty constant, and so grid power consumed as a % of power consumed by the house is rising. This makes me grumpy.
We all act differently. Having power at all times and using only 10 kWh a day should not make you grumpy or the % going in the wrong direction😀😀
Now that my total power use is 300 vs 1200 kWh 10 years ago I don't mind using grid if I have when needed. Just switching things on is easier than putting in a lot of effort to save a unit or 2.
We have about the same load profile but I don't cycle. Also some time slots of LS I don't even switch to inverter.
