Gauteng Who is not using grid....
So going offgrid means also having to invest in a backup generator then, for cloudy days to ensure one's batteries are topped up. Now imagine having taken such a hit as @Scorp007 has and you have an fully electric vehicle🤦‍♂️
  • Replies 157
  • Views 18.1k
  • BritishRacingGreen
    BritishRacingGreen
    Ja, en ek charge my betteries vanaffie grit, en die loadsheddink experts kry a fit 😄
  • Antonio de Sa
    Antonio de Sa
    Here is my system performance yesterday, by 10:30 AM battery fully charged, geyser done and dusted, the rest of the day what a waist.
  • Everyone in Jozi is having cold weather 😝 nice 26° in CPT today with fairly good solar production. I flew down to Jhb yesterday and boy was it cold happy to be back in Cpt today. One of my clients in
2 hours ago, Scorp007 said:
This is 4 times my normal use. We also 2 people.
I recently had a chat with a guy who has to run a fish pond pump 24/7. That 1 item is using more power than what our household uses per day.
Has anyone realised that once you put up a fairly decent PV system your consumption goes up or you get lax about Switching of Switches (SoS)? I remember I killed my old 6 x 200Ah AGM batteries faster with someone just deciding to do some ironing during the day and it was overcast so most of the power was directly coming out of the battery pack, rather than solar...argh....
But don't you know? Solar = free and unlimited.
I fought this fight early on, when I saw the difference our batteries could make when there were outages at night, and I decided that I wanted to err on the side of keeping charge in the batteries. So we don't run the dishwasher at night. Water heating is controlled by timers. Etc.
September for the whole month we consumed 291 kWh, which is actually less than where we were pre-solar.
If nothing else changes you would expect to see a small increase in consumption because the inverter itself consumes some power, and the process of converting AC to DC and then charging the batteries is not 100% efficient.
Everyone in Jozi is having cold weather 😝 nice 26° in CPT today with fairly good solar production. I flew down to Jhb yesterday and boy was it cold happy to be back in Cpt today. One of my clients in Nigel Gauteng phoned me at 11h45 and he just wanted to know if it is normal to get 410w from his 13kwp array. He said it is raining and thick clouds😅
Sad day when I get 300w from my array😂 Eskom must be loving getting some money again
When the sun shines in cpt then solar rocks for sure :)
2 days in a row full sun no fuzzy sky or clouds in sight.
Summer in full swing now so have my daytime 1100watt loads running.
Still need to find an extra 200-300 watts to suck in the full sun after 3pm.
Edited by WannabeSolarSparky
So, how much total production everyone around Gauteng managed to get today? The orientation of the panels shouldn't matter much in a day like today. Let's compare relative to array sizes and brand of panels.
I managed to produce total of 3.7kWh out of 4.3kW array and JA Solar 540W panels.
Here on the East Rand I had 4,8kWh from my 6,4kWp array. JA Solar 535W panels
4.2kWh from a 4.55kWp PV Array [10 x JA 455W] here in JHB.
Enough to scrape through on essentials - but not enough to do much beyond that!
Yesterday was slightly worse - we can see how the cloud-cover (especially when they're thick rain-clouds like the last two days here) hammers production:
Edited by JayMardern
2.9kwh from my 3.3 array
Forget about generation. What about consumption? My home has used 22.4 kWh today so far, which is massive for us. This time last week we used just under 13.
Part of that increase is the heat pump. A week ago it started up at 12 and ran for 20 minutes. Today it started the same time and ran for an hour and 20 minutes. We didn't run the dishwasher today. We did do some washing, but cold cycles.
It looks like Eskom may have correctly anticipated a significant increase in load.
Edited by Bobster.
