September 27, 20187 yr have a guy that needs new batteries at present he has 8 100 ah bats 4s 2p being a old 48v system with about 3.4 kw panels and 2 pwm charge controllers I told him to go with 4 series 12v 200 ah bats to simplify things Now the big questions battery recommendations excl lipo I have been impressed with Omni power in the general range of 2500 cycle lives Trojans are good but seem to be in the 1750 cycle life range or maybe I'm looking at it wrong cheers all
September 27, 20187 yr 9 minutes ago, maxomill said: battery recommendations excl lipo Does this include Li-ion? If not, please consider Pylontech? If so, I would go for Trojan.
September 27, 20187 yr 11 minutes ago, maxomill said: battery recommendations excl lipo Lipo would be lithium polymer. Does that mean recommendations for NMC, LCO and LFP is allowed? :-P
September 29, 20187 yr Author thanks guys but no lipo no pylons as I believe they need to talk to the inverter remember I have a pwm cc to consider looking at 4 x 200ah in series or something trying to get to the 20 k range for complete set also want a victron battery monitor to switch back to Eskom any ideas on that would be appreciated cheers
September 29, 20187 yr 12 minutes ago, maxomill said: also want a victron battery monitor to switch back to Eskom A victron battery monitor has a configurable contact. I use 12 volt through that relay to energize an interposing relay. The relay in turn switches 220 volt to the coil of a 63Amp Contactor. Should the SOC go below setpoint, the grid to the inverters are switched on. Above a certain value it drops out again and i run offgrid till grid is needed again. If this is what you meant. 15 minutes ago, maxomill said: but no lipo no pylons as I believe they need to talk to the inverter I dont think this is completely the case. Unless i have it wrong, but as far as i know @gabriel runs on pylons without any comms link to the inveter. If you want to use SOC as control in ICC for example , then you need a special cable to communicate to the Software. @Chris Hobson. your opinion please?
September 29, 20187 yr 1 hour ago, Jaco de Jongh said: I dont think this is completely the case. Unless i have it wrong, but as far as i know @gabriel runs on pylons without any comms link to the inveter. If you want to use SOC as control in ICC for example , then you need a special cable to communicate to the Software. @Chris Hobson. your opinion please? The Pylons are approved to be used with the following inverters: Goodwe, Victron and Voltronic. There are some other but they have not made it to our shores. When it is operating with a Voltronic product (either an Infinisolar or an Axpert) there is no communication between inverter and the BMS. @Manie's ICC has been approved as an interface between Voltronic products and Pylontech. This helps as you can set the battery to discharge according to SOC rather than voltage.
September 30, 20187 yr Author thanks guys @Jaco de Jongh there wont be any icc but I love the battery monitor idea cheers
November 5, 20187 yr Trojan SAGM 12 205 in the best choice here. Far superior to the Omni power offering. http://livingsolar.co.za/product/sagm-12-205/
