Water Leak Detection
Hi like minded individuals, advice on leak detection how is this done? Gas ? Air? Which is the best method. I’m told repairing leaking is very expensive and insurance won’t pay outright for the repairs once found. Anybody have any experience with this??
Had a leak a few weeks ago - got a guy out to do the detection - he used gas and was able to pinpoint the leak quite accurately. Insurance then sent their own guys who corroborated the findings and repair work started a day later. They dug, replaced the pipe and reinstated any damage they had done to the area. I only had to pay excess of 1k - this is with Naked Insurance
1 minute ago, GreenFields said:
At the same time, see if you can request a rebate from your municipality for the lost water. Might need an affidavit from the plumbers. They should be able to advise.
Tshwane are the worst - they haven't even responded to the leak issue when i discovered there was a leak
I've had issues with a leak - was on the hot water side - water disappeared behind tiles and went underground - so no visible water seen.
Geyser would not heat up - so I replaced the element.
Electricity consumption went up (pre-paid) - I assumed it was a faulty element.
I contacted the Home Owners Comprehensive insurance after the repair was completed by my plumber.
They paid for the gas check and excess metro bill.
What I learnt:
Call your insurance first, log a call, and ask them to send a plumber.
You pay the insurance excess and they pay everything else - repair, gas, metro bill, etc.
EDIT:
Been thinking of adding a smart water meter and connecting it to home assistant for recording and monitoring.
Any recommendations for smart water meter?
Edited by system32
What I learnt:
EDIT:
There is this DIY solution
post-32488964
What I learnt:
EDIT:
There are some water meters with a little pocket next to the counter and you push a probe in the hole which sends out pulses.
The CBi Nano view has got that function and it display water consumption and have a leak alarm option also. Can the Nano export data/alarms to your home assistant?
Hot water leaks are easily found with a thermal camera. I had one case where the pipe ran under the kitchen floor and was leaking there. Guy with a camera found it pretty quickly. He also took away that nice warm spot we used to stand on on cold mornings 😪
